February 6, 20251 yr Hello everyone, I’m trying also to connect the RTC ds1307 in RockPi4C+, but it isn’t detecting by I2C. Informations: RTC ds1307 used: https://www.seeedstudio.com/Pi-RTC-DS1307.html Armbian OS version: 25.2 Kernel version: 6.12.10-current-rockchip64 i2c-7 enabled on armbian-config (> System > Kernel > SY210 > rockchip-rk3399-i2c7) When I run the command: sudo i2cdetect -y 7 shows the error Error: Could not open file /dev/i2c-7' or /dev/i2c/7’: No such file or directory When I run the command: sudo i2cdetect -l shows: i2c-0 i2c rk3x-i2c I2C adapter i2c-3 i2c rk3x-i2c I2C adapter Is someone can help to solve this problem? Thanks
February 6, 20251 yr Solution Check /boot/armbianEnv.txt overlays=i2c1 i2c2 rockchip-rk3399-i2c7 Try this instead: overlays=i2c1 i2c2 rk3399-i2c7
February 6, 20251 yr Author I changed the /boot/armbianEnv.txt with overlays=i2c1 i2c2 rk3399-i2c7 but it continues without detect i2c-7 or i2c-1.
February 6, 20251 yr Author It already detected i2c-7. I think the problem was in the line "overlay_prefix=rockchip", it was commented in the file /boot/armbianEnv.txt. After that, the i2c-7 already detected, but the rtc module doesn't set datetime when the rock4cplus boots without Internet. Do you have any suggestion? Thank you for your help.
February 7, 20251 yr Author It started working after running the following commands: sudo modprobe rtc-ds1307 echo ds1307 0x68 | sudo tee /sys/class/i2c-adapter/i2c-7/new_device Thank you for help.
