February 6, 20251 yr I compiled Armbian Rock-5c bookworm vendor 6.1.99 minimal. WiFi driver extension radxa-aic8800.sh breaks Rock 5C vendor (kernel 6.1.99) boot. I compiled without the extension to confirm. The radxa-aic8800 driver has recently been modified in the download source. I modified radxa-aic8800.sh to download the previous driver version "3.0+git20240327.3561b08f-2" and this does not fix the issue. Ref: Jira AR-2603 Logs attached. Any fix or insight would be good. @amazingfate is this something that you might have ideas about? armbian-hardware-monitor.log rock5c-debug.log
February 7, 20251 yr This is a dkms related issue when BTF is enable. This commit should have fixed it: https://github.com/armbian/linux-rockchip/commit/7294c3d056ca52ba312f1b7cdc5cd2273f7d9766
February 7, 20251 yr Author 19 minutes ago, amazingfate said: This is a dkms related issue when BTF is enable. This commit should have fixed it: https://github.com/armbian/linux-rockchip/commit/7294c3d056ca52ba312f1b7cdc5cd2273f7d9766 How does this relate to Armbian build for vendor kernel? Does it need to be patched or will move by some workflow?
February 7, 20251 yr Quote How does this relate to Armbian build for vendor kernel? Does it need to be patched or will move by some workflow? This commit should be in the source tree if you are using the latest code. I have no idea why the issue happens again. I will check it later.
February 7, 20251 yr Author 5 minutes ago, amazingfate said: This commit should be in the source tree if you are using the latest code. I am using the latest code. Thanks for your response and for checking later.
February 7, 20251 yr Author Solution 11 hours ago, amazingfate said: Please try this fix: https://github.com/armbian/linux-rockchip/pull/328 I did a quick compile and tested Rock 5C vendor minimal. The test was successful. Boot now works and WiFi aic8800 works. Thank you @amazingfate
