- Can I restore to android from armbian on oneplus 8t kebab
- IR receiver stops working after suspend/resume
FreeRDP - build wlfreerdp client with hwacc
This build has disabled ffmpeg, I don't know it is possible to build with it for wayland client. I recommend x11 client because it is the most usable client with the most features. FreeRDP developers is developing a new sdl client for all platforms: linux, mac, wayland, x11, but that is still at an early stage. If you run xfreerdp, make sure to use gfx:AVC444 so that server sends h264 stream to you, then freerdp will use ffmpeg to decode it. You can check /proc/mpp_service/ to see if mpp hardware decoder is used. But don't expect the cpu will be extremely low, freerdp is decoding two avc420 streams and then combine them into one yuv444 frame, and then use cpu to convert yuv444 to rgb, then render it to x11, hardware decoder can only off-load few of the cpu load.
- Anyone using OnePlus 8T?
- We are ready to offer a Bountysource donation to Armbian
Discord/Chrome - Incredibly laggy - Orange Pi 5 Plus
If you are talking about lag with discord webpage, vpu accel won't help because there is no video played in discord. You can check chromium's gpu status at chrome://gpu, see if the gpu driver is working. My ppa only packages chromium for noble, ubuntu 25.04 is not supported. While chromium in my ppa only add patches to let chromium use vpu when playing videos, this should not help improving discord webpage performance.
Debian on BPi-M7 display resolution and resyncing issue on Viewsonic VX3276-2K-MHD
Hi, There are differences between the bookworm and noble images: - bookworm is running vendor 6.1.99 kernel which is from rockchip's sdk, while noble is running mainline 6.12.13. The SDK kernel may have issues detecting screen resolution, you may wait for a new version 6.1.115 to see if the issue is fixed. - bookworm should be running without gpu driver, you can check it by command "dpkg -l|grep libgl1-mesa-dri", if the version is lower than 24.1, the gpu is not drived, you can try bookworm image built with mesa-vpu extension for example the cinnamon one: https://dl.armbian.com/bananapim7/Bookworm_current_cinnamon-backported-mesa - You are running both images with xfce desktop, so the scaling issue may be desktop environment related, usually wayland session(such as gnome wayland) has better support on HiDPI screens.
- AIC8800 wifi sdio module not working with kernel 6.12+
- WiFi driver extension radxa-aic8800.sh breaks Rock 5C vendor kernel boot.
Installing Ambian Bookworm to NVME / M2 SSD
After 20min of fio test, nvme disk is still fine $ sudo fio --name=randwrite --ioengine=sync --rw=write --bs=4k --numjobs=1 --size=1G --runtime=1200s --time_based --directory=/mnt [sudo] password for jfliu: randwrite: (g=0): rw=write, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=sync, iodepth=1 fio-3.36 Starting 1 process Jobs: 1 (f=1): [W(1)][93.4%][w=93.4MiB/s][w=23.9k IOPS][eta 01m:19s] Jobs: 1 (f=1): [W(1)][100.0%][eta 00m:00s] randwrite: (groupid=0, jobs=1): err= 0: pid=5569: Wed Dec 11 10:26:57 2024 write: IOPS=49.7k, BW=194MiB/s (203MB/s)(227GiB/1200478msec); 0 zone resets clat (nsec): min=1166, max=3770.1M, avg=18646.17, stdev=2441229.11 lat (nsec): min=1458, max=3770.1M, avg=18735.33, stdev=2441230.02 clat percentiles (nsec): | 1.00th=[ 1464], 5.00th=[ 1752], 10.00th=[ 2040], | 20.00th=[ 2040], 30.00th=[ 2320], 40.00th=[ 2640], | 50.00th=[ 2640], 60.00th=[ 2928], 70.00th=[ 3216], | 80.00th=[ 3216], 90.00th=[ 4080], 95.00th=[ 4640], | 99.00th=[ 7904], 99.50th=[ 10560], 99.90th=[8716288], | 99.95th=[9109504], 99.99th=[9240576] bw ( KiB/s): min= 24, max=1543457, per=100.00%, avg=227861.36, stdev=262064.21, samples=2093 iops : min= 6, max=385864, avg=56965.30, stdev=65516.07, samples=2093 lat (usec) : 2=7.53%, 4=80.62%, 10=11.27%, 20=0.41%, 50=0.03% lat (usec) : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01% lat (msec) : 2=0.01%, 4=0.01%, 10=0.13%, 20=0.01%, 50=0.01% lat (msec) : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01% lat (msec) : 2000=0.01%, >=2000=0.01% cpu : usr=3.12%, sys=17.15%, ctx=251826, majf=0, minf=12 IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0% submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% issued rwts: total=0,59630438,0,0 short=0,0,0,0 dropped=0,0,0,0 latency : target=0, window=0, percentile=100.00%, depth=1 Run status group 0 (all jobs): WRITE: bw=194MiB/s (203MB/s), 194MiB/s-194MiB/s (203MB/s-203MB/s), io=227GiB (244GB), run=1200478-1200478msec Disk stats (read/write): nvme0n1: ios=0/265014, sectors=0/414735560, merge=0/734, ticks=0/1115350653, in_queue=1115646197, util=98.45%
I'm having a v1.1 board. Now I boot a noble cli image with 6.1.84 vendor kernel. 120s fio test is fine: $ sudo fio --name=randwrite --ioengine=sync --rw=write --bs=4k --numjobs=1 --size=1G --runtime=120s --time_based --directory=/mnt randwrite: (g=0): rw=write, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=sync, iodepth=1 fio-3.36 Starting 1 process Jobs: 1 (f=1): [W(1)][100.0%][w=1079MiB/s][w=276k IOPS][eta 00m:00s] randwrite: (groupid=0, jobs=1): err= 0: pid=4531: Wed Dec 11 01:49:08 2024 write: IOPS=229k, BW=895MiB/s (939MB/s)(105GiB/120116msec); 0 zone resets clat (nsec): min=1166, max=1465.6M, avg=3015.61, stdev=345679.23 lat (nsec): min=1458, max=1465.6M, avg=3105.60, stdev=345687.63 clat percentiles (nsec): | 1.00th=[ 1752], 5.00th=[ 1752], 10.00th=[ 1752], 20.00th=[ 2040], | 30.00th=[ 2040], 40.00th=[ 2040], 50.00th=[ 2040], 60.00th=[ 2320], | 70.00th=[ 3216], 80.00th=[ 3216], 90.00th=[ 3504], 95.00th=[ 4080], | 99.00th=[ 6112], 99.50th=[ 7584], 99.90th=[ 11072], 99.95th=[ 13376], | 99.99th=[749568] bw ( KiB/s): min=49304, max=1457152, per=100.00%, avg=929145.40, stdev=313692.78, samples=236 iops : min=12326, max=364288, avg=232286.35, stdev=78423.29, samples=236 lat (usec) : 2=15.55%, 4=79.07%, 10=5.21%, 20=0.15%, 50=0.01% lat (usec) : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01% lat (msec) : 2=0.01%, 4=0.01%, 10=0.01%, 20=0.01%, 50=0.01% lat (msec) : 100=0.01%, 2000=0.01% cpu : usr=15.40%, sys=77.45%, ctx=52410, majf=0, minf=22 IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0% submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% issued rwts: total=0,27525121,0,0 short=0,0,0,0 dropped=0,0,0,0 latency : target=0, window=0, percentile=100.00%, depth=1 Run status group 0 (all jobs): WRITE: bw=895MiB/s (939MB/s), 895MiB/s-895MiB/s (939MB/s-939MB/s), io=105GiB (113GB), run=120116-120116msec Disk stats (read/write): nvme0n1: ios=1/113583, sectors=8/216264040, merge=0/248, ticks=9/45093762, in_queue=45095689, util=90.05% I'm testing with a 256G NVME SSD.
amazingfate
