February 7, 20251 yr Hello, I read about raxda zero3E edge support, and because I'm having problems with img-6.12.9+bpo-arm64-16k (wireguard dependency) Do you think I could resonably try the edge version and then, I understand that I have to install armbian-bsp-cli-radxa-zero3-edge linux-u-boot-radxa-zero3-edge linux-headers-edge-rockchip64 Is there more to install ? or less ? And, does I have to remove old (vendor) kernel version before ?
February 8, 20251 yr Wireguard is shipped by default with almost all Armbian images. Simply do sudo modprobe wireguard All you need is wireguard-tools which can be installed with --no-install-recommends to avoid unnecessary bloat/dependencies.
February 8, 20251 yr 10 hours ago, d83fr said: because I'm having problems with img-6.12.9+bpo-arm64-16k Also try this way: https://docs.armbian.com/User-Guide_Armbian-Config/Network/#wireguard-vpn-client-server Its easier.
February 12, 20251 yr Author Thanks for replies Will try armbian-config solution when on armbian (and the other on ... other )
