May 4, 20251 yr I really like this small board but with new revision firmware choice is a nightmare... Looking for Debian or Ubuntu with XFCE and support for wifi (usb eth at start if needed ok), bluetooth, HDMI sound, QHD display resolution (2560x1440) Main tests results: - Standard Armbian (V25.2.2 Linux 6.6.75 Ubuntu noble XFCE + overlays=bananapi-m4-sdio-wifi-bt) -> wifi OK, bluetooth NO, HDMI sound NO, bad display perf, buggy screen size (display 1920 when choosing 2560) - Official BPI (V24.8.2 Linux 5.4.125 Debian XFCE + overlays=i2c0 spi1 uart4 -> wifi OK, Bluetooth NO, HDMI sound NO, bug in screen size (limited to 1920) - Other rolling releases, starting from minimal, ...: not better ou worse. Any build you know with better results? Please help.
May 4, 20251 yr The GPU node needs to be enabled. There has been adjustments made to the patching for 6.12.y and above, but I haven't messed with yet. Basically nodes need to be added for sound. As for Bluetooth. I haven't figured out yet why it doesn't work on Armbian. In my personal builds it works fine. I believe there is some patching or service preventing it from loading. But I can't be sure. I've put a lot of time already into the DTS to get this working on both REVS. To much time in my opinion. Anyone is welcome to do a PR and add and enable the bits if they like. Otherwise peps are just gonna have to wait till I get around to it again.
May 5, 20251 yr 04.05.2025 в 14:18, ScoreABSM сказал: Any build you know with better results? Please help. Try some of these images. https://github.com/armbian/os/releases/tag/25.5.0-trunk.507 And please post here what doesn't work with the download link to the image.
May 14, 20251 yr Author Thanks for replying c0rnelius, going, sorry for the delay. Testing 507 (2 Bananapi M4 Zero images available, minimal Trixie and minimal Plucky) I got same result: - no wifi adapter found - adding an ethernet usb I was able to activate network/ssh install/upgrade from another computer - no HDMI sound (no sound cards found) - no bluetooth adapter - no GPU - no change with overlays available (sun50i-h616-bananapi-m4-sdio-wifi-bt, sun50i-h616-gpu) Do you know about other overlays available elsewhere? Thanks Denis - - Edited May 14, 20251 yr by ScoreABSM
May 14, 20251 yr @ScoreABSM Should fix part of the problem; https://github.com/armbian/build/pull/8191 As for Wifi, it works fine for me. Make sure you have an antenna attached or it may not find anything on the network to connect to. As one user already discovered;
May 14, 20251 yr Author Many thanks @c0rnelius but I need clarifications. I agree that for standard build, using overlays (bananapi-m4-sdio-wifi-bt and sun50i-h616-gpu build), wifi (with or without antenna) and GPU are ok, but it is not true for rolling release 570 suggested by @going , and I never got HDMI sound (no sound cards each time). Are you refering to another recent build? If HDMI sound is also available it’s great! And what about bluetooth? When you write wireless do you include bluetooth? Denis Edited May 14, 20251 yr by ScoreABSM
May 14, 20251 yr There are big differences between the two revisions. The biggest one is, one is using Wifi/BT over USB and the other SDIO, which requires the sdio overlay. The reason for BT not working on Armbian, I have yet to figure out. Like I said before, it works on (my personal) a more minimal build; Debian GNU/Linux trixie/sid 6.12.26 #1 Sun May 4 17:50:23 EDT 2025 aarch64 BananaPi BPI-M4-Zero v2 ── DISK Filesystem Size Used Avail Use% Mounted on /dev/mmcblk2p2 29G 2.8G 26G 10% / /dev/mmcblk2p1 466M 74M 363M 17% /boot ── NETWORK Hostname: bananapim4zero Wireless: wlan0 UP 10.0.0.XX Bluetooth: hci0 AC:6A:A3:3B:D9:D6 ── SYSTEM Processor: Cortex-A53 @ 1416MHz 52°C Frequency: 1416MHz Online: 0-3 Governor: performance Memory: 3.8G 199M Entropy: 256 Uptime: 15:13:05 up 4 min, 1 user, load average: 0.01, 0.06, 0. It is hard for me to determine the reasons BT doesn't work, as the patching is very extensive. If it is even the patching? And yes I include the BT node in the overlay; https://github.com/armbian/build/blob/main/patch/kernel/archive/sunxi-6.12/patches.armbian/Add-BananaPi-BPI-M4-Zero-overlays.patch#L267 As for HDMI audio and GPU, the PR I posted a link to corrects this. In future releases and rolling (give it a day) it should now work. Although I think I need to now add my changes to the 6.14.y branch? I'll check.
May 15, 20251 yr Author @c0rnelius new test with latest debian rolling (25.8.0-trunk.5_Bananapim4zero_trixie_current_6.12.23_minimal): - HDMI audio and GPU ok 👍 - no wireless Again my question about overlays: do I need another overlay for wireless? The one I used for standard builds (sun50i-h616-bananapi-m4-sdio-wifi-bt) is not working... Thanks for your help. Denis
May 16, 20251 yr @ScoreABSM If you enable overlay via armbian-config remove "sun50i-h616" in boot enviroment(armbianEnv.txt) should be look like this overlays=bananapi-m4-sdio-wifi-bt https://github.com/armbian/configng/issues/542 Edited May 16, 20251 yr by ZjemCiKolege
May 16, 20251 yr Author Solution @ZjemCiKolege than you! Now wireless is activated by the overlay. @c0rnelius wifi ok but I'm still missing bluetooth (pb with the controller). See dmseg attached. dmseg-H-wifi-bt.txt
