May 27, 20251 yr hi running Armbian 25.2.3 stable 6.1.99-vendor-rk35xx (Ubuntu noble) having to change audio every time on reboot (not sticking after selecting),and maybe not showing as they should ,currently using HDMI 0 but shows as below:
May 27, 20251 yr These commands work for me: pactl list short sinks #shows available audio outputs sudo -H nano /etc/pulse/default.pa #opens the file for editing set-default-sink alsa_output.platform-hdmi0-sound.stereo-fallback #set your default audio output rm -r ~/.config/pulse #delete all files in this folder reboot Edited May 27, 20251 yr by sakittelsen
May 27, 20251 yr Author 1 hour ago, sakittelsen said: rm -r ~/.config/pulse #delete file thanks this is a directory with many files which do i delete ,dont want to break system
