May 30, 20251 yr I've got a ROCK 5B+ with two NVMe drives installed, and for reasons I've not been able to track down, I'm noticing that the `-edge` releases (Kernel 6.14.6) are not able to display more than one of the NVMe drives at once. I've checked various physical configurations (i.e., slot one, slot two, both slots), and only one slot is presented (i.e., output from `lspci` or `lsblk`) – but it doesn't seem to matter whether its slot one or two. If I use a `-vendor` images (6.1.115), I see both devices and can use them without problems. I'd love to be able to provide more information or help debug, but I'm not quite sure where to start here! Cheers Andrew
May 30, 20251 yr Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
