August 17, 20251 yr Let's divide it into parts - Bluetooth Bluetooth isn't working. I've tried activating UART7 and GPIO pins 19 and 22, but to no avail. I installed the drivers, but to no avail. Bluetooth isn't communicating! - Audio ES8388 For some unknown reason, the ES8388 has audio disabled by default on the ASA. To fix this, simply go to the terminal and run the command user@user alsamixer Then use the buttons to move around until you find OUT1. Out1 above it says MM (mute), so click M to make it 00 with a green background. Audio problem solved - Language I can't set the language to Portuguese in the Gnome interface even after installing the packages manually and through armbiam-config - Kernel Please, even if kernel 6.1.xx++ does not work, use the latest functional kernel, for me kernel 6.1.115 is very functional. No critical problems.
August 18, 20251 yr Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
August 18, 20251 yr Author Quote daniel@orangepi5pro:~$ armbianmonitor -u Collecting info and sending to paste.armbian.com, wait... https://paste.armbian.com/uvivupaxen Please post the URL in the forum where you've been asked for. daniel@orangepi5pro:~$
August 18, 20251 yr Author Quote [ 4.262763] Bluetooth: Core ver 2.22 [ 4.262777] NET: Registered PF_BLUETOOTH protocol family [ 4.262780] Bluetooth: HCI device and connection manager initialized [ 4.262785] Bluetooth: HCI socket layer initialized [ 4.262788] Bluetooth: L2CAP socket layer initialized [ 4.262795] Bluetooth: SCO socket layer initialized [ 4.262838] NetLabel: Initializing ..... [ 5.247700] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 122. [ 5.247708] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 29. [ 5.247712] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 22. [ 5.247716] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 21. [ 5.247739] [BT_RFKILL]: Request irq for bt wakeup host [ 5.248043] [BT_RFKILL]: ** disable irq [ 5.248088] [BT_RFKILL]: bt shut off power [ 5.248097] [BT_RFKILL]: bt_default device registered. [ 5.248135] input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input5 ..... Edited August 18, 20251 yr by DanflashX
August 31, 20251 yr Thank you for your report, @DanflashX So, your audio is working out of the box and the change in https://github.com/armbian/build/pull/8568 is not necessary for the Opi 5 Pro?
September 1, 20251 yr On 8/18/2025 at 12:06 AM, DanflashX said: I can't set the language to Portuguese When you do first login, you need to choose correct locales combination and language in desktop should follow - you still need to install desktop packages ... If you don't have locales support in the system, you won't be able to use it in desktop. I think this is the problem. In my case, when I select my own locales (sl_SI.UTF-8) and install those desktop related packages, I have Gnome with Slovene support.
September 21, 20251 yr Author In the case of the Orange PI 5 Pro, just remove OUT1 from mute mode and the ES8388 will work fine! By default, OUT1 is in MM (mute). @laibsch
September 21, 20251 yr Author @Igor When I first start it up, I get an error! Even if I install the packages manually, the GNOMRlE interface does not switch to Portuguese! That's strange!
