Skip to content
View in the app
Armbian Community Forums
New "target is busy" error during latest build attempts
Featured Replies
On my Debian13 VM that I use to build images for my boards, I have started to notice new errors that I have not seen before after this part of the logs...
[🐳|🌱] After updating and cleaning image apt list cache [ 30 files ]
[🐳|🌱] Image installed package hash [ ✅ base-files = 1-trixie-1armbian1-Bb095-U13.8--deb13u4-R55fa ]
[🐳|🌱] Image installed package hash [ ✅ linux-image-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ]
[🐳|🌱] Image installed package hash [ ✅ armbian-firmware = 1-SAa38b-B96c8-R448a ]
[🐳|🌱] Image installed package hash [ ✅ armbian-bsp-cli-rockpro64-current = 1-PC1e15-V9ab0-H3400-Bd2e9-Rf36a ]
[🐳|🌱] Image installed package hash [ ✅ linux-u-boot-rockpro64-current = 2025.01-S6d41-P6e2c-Hbf76-V6f3c-Be4e9-R448a ]
[🐳|🌱] Image installed package hash [ ✅ linux-dtb-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ]
[🐳|🔨]   removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/etc/resolv.conf'
[🐳|🔨]   removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/initctl'
[🐳|🔨]   removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/start-stop-daemon'
[🐳|🔨]   removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/sbin/policy-rc.d'
[🐳|🌱] Removing qemu-user-static binary from chroot [ qemu-aarch64-static during image ]
[🐳|🔨]   removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/bin/qemu-aarch64-static'
[🐳|🌱] Unmounting [ /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210 ]
Once the unmounting of rootfs-nouuidgen-yet begins I notice the following errors spam in the logs, 1000+ lines, and finally the target unmounts successfully and the image finishes building. The images still boot fine.
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy.
[🐳|🔨]   tmpfs /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev tmpfs rw,nosuid,size=65536k,mode=755,inode64 0 0
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev/pts: not mounted.
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/proc: not mounted.
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sys: not mounted
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/tmp: not mounted.
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/var/tmp: not mounted.
umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/run/user/0: not mounted.
Is there a way to adjust some kind of timeout for this to prevent the massive amount of "target is busy" outputs in the logs? Thank you for any help or insights!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
