Skip to content
View in the app
Armbian Community Forums
  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Answered: Module bcache not found on 6.18.10-current-bcm2711
Featured Replies
Hi Armbian forum people!
I'm trying to setup bcache for my openmediavault. But it seems the `bcache` module is not installed?
Quote
root@rpi5b:~# uname -a
Linux rpi5b 6.18.10-current-bcm2711 #12 SMP PREEMPT Fri Feb 13 11:56:58 UTC 2026 aarch64 GNU/Linux
root@rpi5b:~# modprobe bcache
modprobe: FATAL: Module bcache not found in directory /lib/modules/6.18.10-current-bcm2711
Which means I cannot use `bcache` at the moment with openmediavault.
I do know that the bcache has been added only recently:
* https://github.com/armbian/build/pull/9550?ref=blog.armbian.com
*  "Enable BCACHE on Raspberry Pi build"
But no go so far..
Is there anything I can do?
Edited by eduring
Newer kernel packages may not have hit apt repo yet.
Use the build framework to generate a set of kernel packages to be installed via dpkg -i by yourself: https://docs.armbian.com/Developer-Guide_Overview/
./compile.sh BOARD=rpi4b BRANCH=current kernel
  • eduring changed the title to Answered: Module bcache not found on 6.18.10-current-bcm2711
Well if you want to live on the edge, then use egde as branch instead of current :D
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
