Skip to content
View in the app
Armbian Community Forums
Featured Replies
Hi! Sorry for the delay in replying. I just read the thread.
Thanks to a message on Discord about the working 1GB version.
I previously asked Igor if we should create a specific configuration for that 1GB board due to the problems with using different types of RAM.
Currently, the stability of image 6.18 can be resolved with a uboot patch that you can find in the future port/bump to 7.2.
https://github.com/armbian/build/pull/10587
https://github.com/armbian/build/pull/10587/changes#diff-7d199e3b644c9de298a8504c5ed9a99330f89331309413c909578a89a4ffdb19R19
In the PR, uboot is updated from 26.01 to 26.07, including the patches. Does it have functional dynamic memory detection?
If not, adding cubie-a5e-1gb should only involve a few files.
Edited by JuanEsf
More details
For 2/4 GB versions.
Image with kernel 7.2 and uboot 26.07
Although using armbian-config the installation is copied to the NVMe drive, it should boot from the SD card (for now).
Wi-Fi/BT appears to be working.
SPI (mtd0) in Linux. E906 is enabled so you can test the "e906-examples" repository (I haven't tested the "hello world" example that prints via serial yet).
Don't forget to connect the HDMI cable and turn on the monitor!
Edited by JuanEsf
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
