Skip to content
View in the app
Armbian Community Forums
Facebook crash on chromium
Featured Replies
I've seen this same issue with Discord, since March/April this year. Just going to https://discord.com/app (no login necessary) is enough to trigger it. From what I gather, this seems to be some sort of problem with the Chromium build Armbian uses (it appears to be the same build from the xtradeb ppa). This seems to happen on:
1. Raspberry Pi 4 on Armbian Ubuntu Noble
2. Some random Ubuntu VM ARM64 on Apple Silicon using Chromium from xtradeb/apps PPA
3. Dragon Q6A w/ Armbian Ubuntu Noble
No workarounds seem to work. Turning off GPU acceleration, disabling sandboxing, etc. all make no difference.
But it does not occur on:
1. Google Chrome
2. Chromium 145 or earlier ARM64 from Armbian or Xtradeb PPA, on all devices. Only 146 or later is affected for some reason
3. Linux Mint's Chromium x64 build
4. x64 Chromium snap package on Ubuntu
I have not tested xtradeb PPA (or Armbian)'s x64 build of Chromium. Based on the above, I do not think this is an Armbian specific issue. Anyone have any ideas on where to report this?
Perhaps here: https://issues.chromium.org/issues?q=status:open as xtradeb ppa is packaking service only. I don't think they do anything else that that.
This is either older or more recent. Mint probably uses same packages then Ubuntu or issue is architecture specific. Also possible.
Mint packages its own Chromium as a deb package, whereas Ubuntu's Chromium is a snap  (even `apt install` just installs a snap by default). So, all x64 packages work (and I confirmed by testing xtradeb PPA's x64 package, which works).
However, it's also not ARM64 related, as the Chromium ARM64 Snap from Ubuntu 24.04 (I just tested that too) works perfectly fine. It's just the ARM64 deb package from xtradeb that seems broken, which is bizarre.
Software complexity is extreme ...
And only x86 I would assume, so there is very little of interests for us.
It is enough that packages are assembled at different time, so they will have different (bugs &) fixes. Either Ubuntu will get this bug or xtradebs will be fixed. Soon both wil be fixed or both broken .... unless bug is down to the OS level. Where snap will win with its, presumbly, stabilized OS container.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
