Skip to content
View in the app
Armbian Community Forums
RockPi 4b 'board bring up'
Featured Replies
  • Author
3 hours ago, NicoD said:
I saw that "new hardware : RockPi4"
means initial device tree is now upstream.. Doesn't mean that this is complete... e.g. you want thing anything like:
https://github.com/armbian/build/blob/master/patch/kernel/rockchip64-dev/fix-rockpi4b-led.patch
on the other hand, our RX & TX settings for gmac slightly differ:
+	tx_delay = <0x28>;
+	rx_delay = <0x20>;
https://github.com/armbian/build/blob/66b5cea466557222d8a9d4f140f7c9e3b3acee4f/patch/kernel/rockchip64-dev/add-board-rockpi4b.patch#L304-L305
	tx_delay = <0x28>;
	rx_delay = <0x11>;
https://github.com/torvalds/linux/blob/8ff468c29e9a9c3afe9152c10c7b141343270bf3/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dts#L155-L156
maybe this makes a difference.. who knows.. It's not that 5.1 will be boring.. But I would only push if first Ayufan pushes as well and second we can adjust all patches in one attempt..
3 hours ago, TonyMac32 said:
Well, there has been a lot of peripheral stuff going I with Rockchip as well,
It's not that there isn't anything interesting.. :P You will probably know in which parts I'm interested due to a few PMs.. :D:lol: But I still think that some of them are just not ready yet.. Or might need additional DT tweaking.
I think 5.2 may be the more interesting
and then.. 5.3 will be more interesting cause maybe a LTS kernel (~3 months/kernel means november - okay.. if we assume 2 months/kernel then it will be 5.4 :D who cares)..
We definitively should push to either 5.1 or 5.2 to avoid having to much to fix later.. But it's IMO not priority.
  • Author
Hi,
I try to set up the server of Armbian_20.02.1_Rockpi-4b_buster_current_5.4.20.img -  as the boot was very slow I wanted to see the systemd-analyze plot
systemd-analyze plot > RockPi4B_boottime-$(date +%Y%m%d_%H%M%S).svg
Bootup is not yet finished (org.freedesktop.systemd1.Manager.FinishTimestampMonotonic=0).
Please try again later.
Hint: Use 'systemctl list-jobs' to see active jobs
tido@rockpi-4b:~/just_data$ systemctl list-jobs
JOB UNIT                                 TYPE  STATE
109 rk3399-bluetooth.service             start running
  1 graphical.target                     start waiting
110 systemd-update-utmp-runlevel.service start waiting
  2 multi-user.target                    start waiting
4 jobs listed.
The system itself is updated and rebooted:
Spoiler
All packages are up to date.
root@rockpi-4b:/home/tido/just_data# apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
RPi-Monitor doesn't work on Buster, but did so on   Armbian_20.02.1_Rockpi-4b_bionic_legacy_4.4.213_desktop.img
Spoiler
root@rockpi-4b:/home/tido/just_data# armbianmonitor -r
Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor
/usr/bin/armbianmonitor: line 697: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory
/usr/bin/armbianmonitor: line 193: /etc/rpimonitor/template/raspbian.conf: No such file or directory
/usr/bin/armbianmonitor: line 196: cd: /etc/rpimonitor/: No such file or directory
sed: can't read /etc/rpimonitor/template/temperature.conf: No such file or directory
sed: can't read /etc/rpimonitor/template/cpu.conf: No such file or directory
sed: can't read /etc/rpimonitor/template/version.conf: No such file or directory
Now you're able to enjoy RPi-Monitor at http://192.168.11.5:8888
Is this in relation with the 5.x Kernel?  Linux rockpi-4b 5.4.32-rockchip64 #20.02.11 SMP PREEMPT Tue Apr 14 17:30:19 CEST 2020
Looks like bluetooth was responsible for the 'hanger'..    and a picture of the situation:
It was difficult to get a proper plot, so that gThumb doesn't crash. I reached that goal by disabling:   sudo systemctl disable rk3399-bluetooth.service ;  the plot reduced from 1,4MB to 181kB.
However, the boot itself takes an eternity, here some more details, from serial-getty@ttyS2.service (at 66 seconds) to launch  user-1000.slice  (at 134 sec.)  Booting completed at 145 seconds.
and 68 seconds later it continues:
Edited by Tido
systemctl stop bluetooth.service
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
