Rdlop
  1. Hi, I'm using it at the moment as a containers server, thanks for link. I not that changing kernel may run in trouble, so I still keep the 6.1.115 and wait for update. Thanks for your help Regards
  2. I'm using Armbian Orange Pi 5 Plus based on Debian 13 with vendor kernel v26.2.1 for Orange Pi 5 Plus running Armbian Linux 6.1.115-vendor-rk35xx I'm thinking about switching to Armbian based on Debian 13 with kernel current 6.18.33 because 6.1.115 is an old one => current the kernel is more recent Is that a good idea to swith to vendor kernel to current ? How can I do this ?
  3. I've seen the latest kernel in armbian-config, installed it with armbian-config. I'll see if next release will be fetch automatically. Thanks for answer ! armbianmonitor -U 5484 PRETTY_NAME="Armbian 25.2.2 bookworm" 5485 ARMBIAN_PRETTY_NAME="Armbian 25.2.2 bookworm" 5486 5487 ### Installed packages: 5488 5489 ii armbian-bsp-cli-orangepi5-plus-vendor 25.2.2 arm64 Armbian CLI BSP for board 'orangepi5-plus' branch 'vendor' 5490 ii armbian-config 25.5.0-trunk.157.0305.102925 all Armbian config: The Next Generation 5491 ii armbian-firmware 25.2.2 all Armbian - Linux firmware 5492 ii linux-base 4.9 all Linux image base package 5493 ii linux-dtb-vendor-rk35xx 25.2.2 arm64 Armbian Linux vendor DTBs in /boot/dtb-6.1.99-vendor-rk35xx 5494 ii linux-image-vendor-rk35xx 25.2.2 arm64 Armbian Linux vendor kernel image 6.1.99-vendor-rk35xx 5495 ii linux-u-boot-orangepi5-plus-vendor 25.2.2 arm64 Das U-Boot for orangepi5-plus
  4. how can I update by using unattended-upgrades the whole system kernel too ? (I mean like in Debian distribution) ?
  5. @Igor armbian-config was not installed, after installation the kernel upgrade were not frozen.
  6. dpkg-divert --no-rename --add /etc/apt/apt.conf.d/02-armbian-periodic I've modified that file not to be erased during update which contains // Enable the update/upgrade script (0=disable) APT::Periodic::Enable 1; // Do apt-get update automatically every n-days (0=disable) APT::Periodic::Update-Package-Lists 1; // Do apt-get upgrade --download-only every n-days (0=disable) APT::Periodic::Download-Upgradeable-Packages 1; // Run the unattended-upgrade security upgrade script // every n-days (0=disabled) // Requires the package unattended-upgrades and will write // a log in /var/log/unattended-upgrades APT::Periodic::Unattended-Upgrade 1; // Do apt-get autoclean every n-days (0=disable) APT::Periodic::AutocleanInterval 20; // Define basic patterns //Unattended-Upgrade::Origins-Pattern { // origin=,codename=; // origin=Armbian; //}; APT::Periodic::Update-Package-Lists 1; APT::Periodic::Verbose 1; Unattended-Upgrade::Remove-New-Unused-Dependencies true; Unattended-Upgrade::Remove-Unused-Dependencies true; Unattended-Upgrade::Automatic-Reboot true; Unattended-Upgrade::Automatic-Reboot-Time 02:30; Unattended-Upgrade::Origins-Pattern { origin=*; }; Do you think that file might be the problem ? Also package are updated : cat /var/log/apt/history.log Start-Date: 2025-03-04 01:00:37 Commandline: /usr/bin/unattended-upgrade Upgrade: armbian-firmware:arm64 (25.2.2, 25.2.2) End-Date: 2025-03-04 01:00:40
  7. Seems some packages are not on 25 version
  8. # armbianmonitor -U 1 2 ### lsusb: 3 4 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub 5 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 6 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub 7 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 8 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 9 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 10 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 11 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 12 13 /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 14 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 15 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 16 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 17 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M 18 |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M 19 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M 20 |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M 21 22 ### Userland generated with Armbian Build Framework: 23 24 PRETTY_NAME="Armbian 25.2.2 bookworm" 25 ARMBIAN_PRETTY_NAME="Armbian 25.2.2 bookworm" 26 27 ### Installed packages: 28 29 ii armbian-bsp-cli-orangepi5-plus-vendor 25.2.2 arm64 Armbian CLI BSP for board 'orangepi5-plus' branch 'vendor' 30 ii armbian-firmware 25.2.2 all Armbian - Linux firmware 31 ii linux-base 4.9 all Linux image base package 32 ii linux-dtb-vendor-rk35xx 24.8.1 arm64 Armbian Linux vendor DTBs in /boot/dtb-6.1.75-vendor-rk35xx 33 ii linux-image-vendor-rk35xx 24.8.1 arm64 Armbian Linux vendor kernel image 6.1.75-vendor-rk35xx 34 ii linux-u-boot-orangepi5-plus-vendor 25.2.2 arm64 Das U-Boot for orangepi5-plus
  9. Do you have `man armbianmonitor` i'd like to see output before send it to paste.armbian.de ?
  10. apt-mark showhold N: Ignoring file '02-armbian-periodic.distrib' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension
  11. I'm using Orange Pi 5 Plus, I've updated to latest by apt upgrade but seems to be stuck on old version as you can see 25.2.2 but kernel is still 6.1.75 : # uname -a Linux abeure 6.1.75-vendor-rk35xx #1 SMP Wed Aug 21 11:45:59 UTC 2024 aarch64 GNU/Linux # cat /var/log/apt/history.log Start-Date: 2025-02-25 01:00:39 Commandline: /usr/bin/unattended-upgrade Upgrade: armbian-firmware:arm64 (25.2.1, 25.2.2) End-Date: 2025-02-25 01:00:42 Start-Date: 2025-02-25 01:01:10 Commandline: /usr/bin/unattended-upgrade Upgrade: linux-u-boot-orangepi5-plus-vendor:arm64 (24.11.1, 25.2.2) End-Date: 2025-02-25 01:01:11 Latest version https://www.armbian.com/orange-pi-5-plus/ does not seems to be fetched. Armbian 25.2.1 Bookworm Minimal / IOT Kernel: 6.1.99, Size: 295.5 MB, Release date: Feb 15, 2025 Can you explain what i've missed ?
  12. I don't have any packages installed dpkg -l | grep -i mesa I'm using v24.8.4 for Orange Pi 5 Plus running Armbian Linux 6.1.75-vendor-rk35xx Can you check if the firmware is loaded by the kernel ? dmesg|grep Mali [ 367.986293] mali fb000000.gpu: Loading Mali firmware 0x1010000 [ 367.988606] mali fb000000.gpu: Mali firmware git_sha: 814b47b551159067b67a37c4e9adda458ad9d852
  13. find /lib/modules/ -name \*panthor\* -ls 6950038 4 drwxr-xr-x 2 root root 4096 août 26 18:21 /lib/modules/6.1.75-vendor-rk35xx/kernel/drivers/gpu/drm/panthor 6951151 180 -rw-r--r-- 1 root root 182920 août 24 19:27 /lib/modules/6.1.75-vendor-rk35xx/kernel/drivers/gpu/drm/panthor/panthor.ko I've got them right. And yes i'm doing headless
  14. dmesg | grep -i panthor Does not return anything
