- Radxa 5B Plus - Microphone Audio Jack support
- How to enable overlays for PWM and Radaxa 4k camera
- 25.5.0-trunk.185_Orangepi5-max build break the HDMI output from Mar 6, 2025
- Orange pi 5 Ultra and pwm
Hi I'm trying to use Armbian with Orange pi 5 Ultra. So far so good The hdmirx is working great! I'm not able to control my gpio pins with PWM in equivalent to orange pi 5 ultra image. I guess that i need to load additional overlays, Am I correct? Please review the armbian logs here: https://paste.next.armbian.com/nekodihico I also noticed that pin numbers were changed if I compare it to the Orange pi OS. Thanks in advance!
Orange Pi 5 Ultra Support
My main issue with RPI5 is the lack of hardware video encoder which is extremely disappointing! Radxa team is checking the HDMI issue on their board (they are using 3588 as well) - https://forum.radxa.com/t/hdmi-input-support/25740/8 3588 should support 4k 60fps in theory but there are many complaints about using WIFI, BTH & USB in parallel that leading the losing signals when working with HDMI input.
Can you suggest alternatives for using HDMI input? So what is the solution if i want to consume 4k 60fps video?
I will try to join the effort too I'm not able to find the hdmirx binaries at all. I compiled armbian without any modifications. Am I missing something?
Thank you. I see a lot of patches around this area in the build project. I will take a look. thank you! What is your recommendation about consuming video? using only CSI?
thanks for the reply. I was able to build armbian from scretch with the new module based on orange pi max. Can you guide me how to add hdmirx to the kernel? at the moment I'm not able to use the HDMI input at all
