Clearfogpro : boot from sata (M.2 SSD)
@laibsch - I have my clearfog booting directly off SATA at this point. I achieved this a while ago by writing a "special" uboot binary to the very start of my SATA SSD, and later by writing an enhanced uboot image via `armbian-config` to SPI flash which doesn't require anything else. It's a very simple configuration now and much preferred over the old way. Good luck keeping your system operational and running well!
trixie apt warning: "Policy will reject signature within a year"
I also upgraded from bookworm to trixie and saw this warning. I can confirm that Igor's suggested workaround addresses it: wget https://apt.armbian.com/armbian.key gpg --dearmor < armbian.key | sudo tee /usr/share/keyrings/armbian.gpg > /dev/null apt is now happy with the armbian repo.
- TTL to RS232 console adapter
Do you know of any products that integrate one of those chips such that you can plug in DB9 or RJ45 RS232 and achieve a console on a rockchip system that uses 1.5mbit @ TTL voltages? I have console cables that work now but via USB and I want to wire it up to my terminal server (ideally without having to do any soldering or work my own PCB).
- Helios4 doesn't boot after upgrading to linux-6.6.71 (linux-image-current-mvebu_25.2.0-trunk.343)
I suspect I'm talking to myself here, but for anyone with a clearfog base or pro system, by following similar steps to what was outlined here I've been able to get my clearfog base system to boot and operate correctly using the latest kernel image and other packages. Additionally, as I covered previously in this thread, I had been dragging an old sata-capable u-boot binary around but I installed u-boot to SPI using armbian-config and after doing that I don't think it's necessary and longer (and maybe hasn't been for a very long time...) to fuss with installing it to the boot media. Just change the jumpers to use SPI and let it go. To use the latest kernels, there's an issue where the kernel and initrd grew and overlap now which caused the breakage. Add this to /boot/armbianEnv.txt before installing the new kernel: I then unheld all the packages and rebooted and now I'm on all current software.
Slightly off topic, but a very similar problem (if not exactly this problem) is a current issue for clearfog base and pro as they're based on the same SoC and use the same kernels. I had been running on an older kernel with some packages (including the kernel) held by dpkg. I also had never installed u-boot to SPI before (running it off my boot media instead). This morning I installed a newer u-boot to SPI (maybe not necessary), included the same offsets to armbianEnv.txt, unheld all packages, upgraded everything and rebooted - and everything worked. Thanks to everyone that contributed information here. Hopefully we can keep these systems running for a bit more now!
Clearfog Base with NVMe
I don't use my Clearfog Base as a filer or anything, but I much prefer to have some snappy storage on systems that I access frequently - and since this system is my firewall, I end up working on it often enough. When I'm not at home it's often where I push files - so running off an SD card is right out. For years now I've been using an m.2 SATA drive which has been fine, but it's got a minipcie slot just sitting there that I've never used... it's not particularly fast (PCIe gen 1 x1) but with one of these and an m.2 NVMe drive (the older the better...), you can get much better perf than SATA. You can't boot off it (at least I don't know how to make that happen) but it's easy enough to do that via an SD card or SATA and use one of these for the root filesystem or /home, etc.
What are we running as routers / firewalls these days?
Thanks for those that answered. I was hoping someone would bring up a board targeted at networking (router / firewall) that was well supported by modern software, but nothing is really jumping out. Here are some more random thoughts on the matter... since my previous experience was with SolidRun Clearfog Base (and with Armbian it was quite positive!) I am interested in their newer Clearfog CN9130 Base but it's a bit expensive and I'm hesitant to use anything not supported by Armbian due to poor experience with vendor images. But it looks cool! MACCHIATObin double shot isn't new, and doesn't have the best support either from what I can gather - but it also is attractive. And lastly, Honeycomb LX2 is pretty boss as well - but it also is a bit dated now, isn't cheap, and seems to have not caught on well so doesn't have great software support. All of those seem like nice hardware but I don't expect the software experience to warrant buying one. I had an impulse to buy when I saw the new dual 2.5gbe HAT from Radxa as I have a Rock 4a that claims to support it. I've had that little box in use as a container host running simple services like DNS, DHCP, Unifi controller, etc for a long time now and it's been nothing but reliable - though I do need to evacuate it so I can try bringing it up running Bookworm (it's on Bullseye still - but it's stable!). But I just noticed that maybe its own software support is rotting... it's community supported and the last Armbian image for it is quite old, so maybe I shouldn't put any more money or effort into it and let it do its thing. Dunno. But yeah, a tiny system that is quite low power which supports 2 x 2.5gbe and 1gbe along with NVMe sounds pretty nice especially since I already own the SBC... I suppose what I should really do is continue to ride my existing router until it dies. Considering I locked the kernel and firmware I expect it will work for a long while at this point, though I don't figure it to be able to upgrade to the next major Debian release once it's available. Maybe by then the support for Rock 5 ITX will be solid and I can start using it for this. If anyone else runs Armbian systems as their firewall, please chime in with thoughts and experiences!
Thanks - that's a couple options I should keep in mind: adding the router to a hyperconverged setup running one-armed against a switch via VLANs I've enjoyed having a separate WAN and LAN link for so long that I fell into looking for boxes with 2 physical links but that's totally not a requirement and you're right.
I’ve been rocking a Solidrun clearfog base with Armbian for ~10 years now as my home router and was very happy with it until a few months ago when the newer software updates began to break it. I think the software support is beginning to rot due to not many users and thus no push to maintain it. I figure it’s time to start looking for a replacement. I have a Rock 5 ITX that could do it but I’ve been trying to keep it on the vendor kernel so it can transcode in hardware for Jellyfin - but that vendor kernel has issues reliably detecting the SATA controllers - and I don’t want to have to reboot my router multiple times to get the hardware to work after applying updates. i also just got a Radxa Orion o6 which is awesome hardware but still quite raw. I don’t trust it for a router and it’d be overkill anyways. And I have some stupidly powerful x64 systems that eat a bunch of power but are otherwise up to the task. But I don’t want to go that way. What do you use these days for affordable, performant, and low power routers? At least two gbe ports (10g or multigig preferred), enough CPU to NAT and forward for 500m/30m cable connection, and handle wireguard at a good clip. Preferred serial console … support for Debian / Armbian. I don’t care about a GPU. What do people use these days?
As seen in some other threads for mvebu-based boards (helios4, etc), the current images for clearfog base (and I assume) pro are broken in that it appears the initrd can't be loaded. I also haven't been able to use the u-boot for SATA booting in a while. I have been hitting both of these issues for a while and as I showed above in the past you can still flash old images, use an even older u-boot binary for SATA and get up and running - but now (and I'm not sure when it started) any upgrade to current packages renders the system unbootable. It's unfortunate, but it seems these boards are old enough that their support is rotting (and to be clear, I'm not blaming Armbian for this). While this hardware is old it's plenty performant as my home firewall to the Internet and so I don't want to replace it - but it's maybe time to start looking for a replacement anyways. Just a few nights ago, I installed updates for the first time in a few months and when I rebooted it, it failed to come back up. Considering this is my router, that really cramped my style! But I got another box in place in this role and since then I've poked at this a bit. It's easy to reproduce: Flash a copy of Armbian_23.11.1_Clearfogbase_bookworm_current_6.1.63.img to an m.2 SATA drive (if this isn't available any more, ping me and I can post it somewhere). Write a copy of the old u-boot for SATA support to the beginning of the drive (dd if=u-boot.sata of=/dev/foobarbaz bs=512 seek=1) Put the m.2 SATA drive into your clearfog and configure the jumpers to boot off SATA - see here. Plug in ethernet and micro USB to another system and attach to it for console (picocom -b 115200 /dev/ttyUSBFOOBARBAZ) Power it on and hopefully observe it boot - then go through the initial setup Update and upgrade packages (apt update && apt upgrade) Reboot - and watch it stall before it gets anywhere The trick then is to put a "hold" on the kernel and firmware packages before doing #6. The latest kernel I've been able to get running stable is 6.6.63-current-mvebu (installed via armbian-config). for pkg in armbian-bsp-cli-clearfogbase-current armbian-firmware linux-dtb-current-mvebu linux-image-current-mvebu linux-u-boot-clearfogbase-current; do echo "$pkg hold" | dpkg --set-selections done Then you should be able to upgrade everything else and reboot and have it not break. That list of packages is likely larger than it really needs to be, but after rebuilding my drive a couple of times I decided to not take any chances. The rest is either pure Debian or at least things that shouldn't break due to bit rot. If I have more time I'll try to actually dig in and figure out what's wrong with the ramdisk (or whatever it is that causes this) and submit a fix, but this is better than nothing for now.
So I don't know exactly what is wrong with the latest posted clearfog images (other than the u-boot.sata binary doesn't work), but after using the process I detailed above, I just let apt upgrade everything - including the kernel to 6.6.63-current-mvebu) and so far everything seems to be working after a reboot. I might get this back into production as my home router today after all once I run a few more smoke tests!
I should have mentioned, the above output came from using an old u-boot.sata that I rescued off my old install. When I used the one included in the new build, I didn't get any console output from uboot at all. I have since reverted to an older image from the archive (Armbian_23.11.1_Clearfogbase_bookworm_current_6.1.63.img). Using its u-boot.sata I also got no console output, but with my older one, I have been able to at least get this image to boot! So there's a recipe at least for getting something somewhat modern (if you consider an image that's over a year old "modern" - and from where I'm coming from I do!). Do I dare try to move its kernel forward? Or should I just settle with what I have and move along... I'm attaching a copy of the older u-boot.sata file that is working for me in case it's useful to anyone else. Oh, who am I kidding - this is a really old board and nobody is using them now. u-boot.sata
blood
