odoll
  1. Thx 2, but how do we go there from the boards page, these days!? After not been around for a while I'm happy to find out that Igor still (re)-supports the Espressobin board. Though the homepage had been redesigned heavily I was missing e.g. the links to the adapted u-boot files, rescue stuff, etc. - thx
  2. OK thx - rather than Jammy I think I finally got bookworm to "fly", but the freshly flashed image booted without network, and thus the initial setup is a bit cumbersome. As from the "logs" below I had to unmask the systemd-networkd.service first, before the network ports became usable ... PS: Beside just unmasking the service with systemctl unmask systemd-networkd.service it has to be enabled as well with systemctl enable systemd-networkd.service to have it started after a reboot.
  3. BTW: How would you (easily) install armbian-config, if you don't have internet connection? 😉 But yes, as it's part of the jammy / booksworm builds: I've tried set stauts of some ports to managed, or to set a static IP address - no success.
  4. Sorry folks, I think I'm suffering from the the same 'disease', but I'm still 'blind' to see the solution to the following issue. I'm on a v5 board to which I flashed the "new" uboot version a long time, ago. (I think I flashed flash-image-DDR3-1g_2cs_2-800_800.bin that time as I had timing issues with the version with higher speed.) Though I could get the system to boot after the reset of the uboot environment I never was able to get the i-net running on the applied images, so I gave up in the end. "Messing around" with my Cubietrucks atm I thought I would give the espressobin a second try, but still without success. To me it looks like network manager is running and when I set "/sbin/ip link set dev wan up" as suggested by @y52 the wan-port will get ipv6 addresses (I have to connections to the i-net), but no ipv4 ones. So what do I have to do to get those (in the meantime community versions of bookworm etc.) to work? (thx!) root@espressobin:~# nmcli device show GENERAL.DEVICE: eth0 GENERAL.TYPE: ethernet GENERAL.HWADDR: 5A:FD:04:25:F9:14 GENERAL.MTU: 1508 GENERAL.STATE: 10 (unmanaged) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: on IP4.GATEWAY: -- IP6.ADDRESS[1]: fe80::58fd:4ff:fe25:f914/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256 GENERAL.DEVICE: lan0 GENERAL.TYPE: ethernet GENERAL.HWADDR: 5A:FD:04:25:F9:14 GENERAL.MTU: 1500 GENERAL.STATE: 10 (unmanaged) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: off IP4.GATEWAY: -- IP6.GATEWAY: -- GENERAL.DEVICE: lan1 GENERAL.TYPE: ethernet GENERAL.HWADDR: 5A:FD:04:25:F9:14 GENERAL.MTU: 1500 GENERAL.STATE: 10 (unmanaged) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: off IP4.GATEWAY: -- IP6.GATEWAY: -- GENERAL.DEVICE: wan GENERAL.TYPE: ethernet GENERAL.HWADDR: 5A:FD:04:25:F9:14 GENERAL.MTU: 1500 GENERAL.STATE: 10 (unmanaged) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: on IP4.GATEWAY: -- IP6.ADDRESS[1]: 2a02:908:nnnn:nnnn:58fd:4ff:fe25:f914/64 IP6.ADDRESS[2]: 2002:mmmm:mmmm:0:58fd:4ff:fe25:f914/64 IP6.ADDRESS[3]: fe80::58fd:4ff:fe25:f914/64 IP6.GATEWAY: fe80::1eed:6fff:fe07:29bd IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256 IP6.ROUTE[2]: dst = ::/0, nh = fe80::1eed:6fff:fe07:2> IP6.ROUTE[3]: dst = 2a02:908:nnnn:nnnn::/64, nh = ::, > IP6.ROUTE[4]: dst = ::/0, nh = fe80::b2f2:8ff:fe23:29> IP6.ROUTE[5]: dst = 2002:mmmm:mmmm::/64, nh = ::, mt > GENERAL.DEVICE: lo GENERAL.TYPE: loopback GENERAL.HWADDR: 00:00:00:00:00:00 GENERAL.MTU: 65536 GENERAL.STATE: 10 (unmanaged) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- IP4.ADDRESS[1]: 127.0.0.1/8 IP4.GATEWAY: --
