JRD McLAREN
  1. Ok .. sorry ... It is all "WIP" dts files / attachments. They don't work correctly on the device. (my testing files, posted in this thread, when I'm stuck "somewhere" and asking for help) ..all files like meson8b-sencor.dts, meson8m2-mxiii-plus.dts ... etc.
  2. link from armbianmonitor - https://paste.next.armbian.com/kozaluhulo ..and ... can anybody / admin or moderator remove "my files" /old dts/ from posts above please .. ?? ..thanks...
  3. SO, I have working dts / dtb file for this device now.😃 It has working: - TF card / SD card slot - 2x USB ports (1+1) - HDMI - WIFI card - LAN 100Mbit - IR port - LEDs (red and blue) - CPU 4x - RAM 1GB - Serial console TODO: Nand flash - it will be good to have 8GB internal flash available for system AUDIO&CompositeVIDEO - yes, have sound will be good too .. JTAG - maybe ?? RTC - maybe ?? .. but, I'm not sure, if all of them is possible .... for this SOC... It runs on Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz image kernel is 6.12.17-current-meson - not latest one - because newer version have not 8198es module / driver meson8b-smp5000pro.dtb meson8b-smp5000pro.dts
  4. OK .. now i must "cleanup" all voltage regulators
  5. Is there anybody, who can help me with wifi module ..? or.. any utility to test / check gpios or. help me with gpio mapping in dts ..?? when I use dtb for meson8m2-mxiii-plus.dtb "Tronsmart MXIII Plus" tv box, wifi works fine... but, when I can replicate it on "my" dts for sencor (meson8b-sencor.dts) I have no success (two attached files for compare) Thanks.... meson8m2-mxiii-plus.dts meson8b-sencor.dts
  6. Chips: Amlogic S805 SOC Hynix H5TQ4G63AFR-PBC - DDR3 RAM -2x IP101GR - 10/100Mbps transceiver MT29F64G08CBABA - NAND Flash Memory RTL8189ETV - Wifi module
  7. some photos ... and dts file with working hdmi, lan and two usb ports, "RED" led --- TESTED meson8b-sencor.dts
  8. Yes, I know ... I will try it, when I have "working" dtb .. Now I have extracted original dtb from boot partition...
  9. bootlog file - from stock adnroid boot printenv - stock uboot enviroment printenv boot.log
  10. So, I'm got this "old" TV BOX as a gift, and I'm try to do something with this ... Now I have booted image for Odroid C1 (after 2 or 3 days work) Req. HW mod: - two resistors / wires for working console are needed - pics later HW & SW info: TV Box Name: Sencor SMP 5000PRO CPU: amlogic meson8b (s805 ??) Armbian build file name: Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz DTB file used: meson8b-odroidc1.dtb Kernel Version:6.12.13 Distribution Installed: bookworm Working Ethernet (Yes/No):??? Max Ethernet Speed that works: 100 Does wifi work (Yes/No): ???? Does bluetooth work (Yes/No):NO ?? Does HDMI audio work (Yes/No): It is Androind TV box, 1GB RAM, NAND flash 8GB, 1x LAN, WiFi, 2x USB 2.0, HDMI, SDcard slot, IR, 2 color status led, audio jack, Android 4.4.x I can provide some rom files, from stock android, or whole nand. and (maybe) need some help with this .. (thats all for this midnight)
  11. Here is my actual working init script for bluetooth. It works on Armbian Linux 6.6.36-current-sunxi64 v23.8.1 Bookworm board is Orange Pi Zero Plus 2 H5 no additional dtb overlay is needed, no extra modules just install bluetooth support and devmem2 package - https://ubuntu.pkgs.org/22.04/ubuntu-universe-arm64/devmem2_0.0-0ubuntu2_arm64.deb.html then enable script via 'systemctl enable ap6212-bluetooth' and check /etc/default/ap6212 file ... ap6212-bluetooth
  12. check if zz-10-override-wifi-random-mac-disable.conf zz-20-override-wifi-powersave-disable.conf exists on /etc/NetworkManager/conf.d directory.
  13. Ok .. Now I have some chips for sale ... in Europe ... ..and OPiZeroPlus is fixed ...
  14. Hello .. I have tested both current release 24.2.1 (jammy and bookworm) on OPiZero, and usb otg not working .. on both .. Kernel is 6.6.20-current-sunxi module g_serial is loaded ttyGS0 exist serial-getty@ttyGS0.service is runing dtc overlays are usbhost0 - 3 ..all looks good on opizero side ... but on "computer side" not.. nothing happened when usb cable is plugged in .. no ttyAMC0 device was created .. no new usb hardware can be found in system log ... ..nothing.. Buster version works well... (my old installation) any advice ..? or it is any "actual kernel problem" .. ?? have somebody the same problem .. ??
  15. ..yes I know ... lcsc have required chips also .. ..but ..time ... (and I can recycle some stuff, maybe)
