Skip to content
View in the app
Armbian Community Forums
Can a flash drive be used for installation
Featured Replies
I prefer to use a usb drive and you can boot from It. This way you get 150 MB/s instead of 20 MB/s and you can feel your box like a Desktop PC.
Edited by maka
  • Author
thanks @SteeMan for answering my question.
I had a look at your [git hub PR](https://github.com/armbian/build/pull/4296) and it's really good stuff! thank you for your time & effort in helping community make armbian run on amlogic tv boxes.
I'm a web developer but I love linux. I've cloned the armbian repository and tried to build it locally(both using my local ubuntu 20.04 and docker ). Unfortunately, I wasn't able to compile it as it blows up my local storage so quickly (about 7G - 8G  in 20 minutes and the build is still in progress. I chose BUILD_ONLY=u-boot,kernel )
I'm curious if the experience I had was to be expected.
I've read some post you guys have discussed in the past, and here is what I've learnt so far
* all soc vendors has their own legacy u-boot which are both bespoke and outdated
* some  vendor u-boot has boot order configured as sd card first, and you are lucky if you have such a device (e.g. rockchip rk3318/3328). You can use a mainline u-boot to boot the tv-box
* some vendor u-boot always boot from emmc, e.g. amlogic s905 series , but they left a back door which allows chainload uboot (the presence of aml_autoscript) to a customized image (I have a ps classic and it seems to be the same case)
* some vendor u-boot always boot from emmc and there is no back door left. In this case, you have to burn image into emmc via UART e.g.  all hi-silicon socs
If you can point out any mistakes in my understanding , that'd be much appreciated
another question, since I wasn't able to build image myself (run out of storage too quickly), I downloaded prebuilt images. After I burnt them into my usb flash drive, I noticed there are 2 partition created. One is uboot and the other is linux rootfs (plus install-aml.sh which was put via `family_tweaks()`). I've also downloaded some prebuilt images of other boards, but  they seem to only have one image. If you can comment on this, that would be great!
Again, great project, and great ppl! Thank you so much for helping the community and I'm keen to help the community as well!
Edited by joggingMulberry
Dear joggingMulberry,
this distribution is made mainly for developer board. You have to install it on a sd card. After that you can install it from command line to a flash drive. Please follow our
Quick installation guide
  • SteeMan locked this topic
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
