Skip to content
View in the app
Armbian Community Forums
Orange Pi Zero 2 - Custom DTS Overlay and GPIO Allocation conflicting with image DTS - All header pins pre-allocated for use - which ones are free to use?
Featured Replies
I'm using image Armbian_23.8.3_Orangepizero2_bookworm_current_6.1.53
I'm building a DTS overlay for a SPI Touchscreen and every pin I try to use is showing this error:
[    1.441808] sun50i-h616-pinctrl 300b000.pinctrl: pin PC11 already requested by 5011000.spi; cannot claim for 300b000.pinctrl:75
[    1.441817] sun50i-h616-pinctrl 300b000.pinctrl: pin-75 (300b000.pinctrl:75) status -22
[    1.441829] sun6i-spi 5011000.spi: cannot register SPI master
I'm trying to configure my touchscreen dts to use the SPI1.0 & SPI1.1.  However, the pins exposed on the headers are all allocated for device use under 300b000.pinctrl.
How do you allocate header pins for another use?
I need 5 pins + SPI1 for the touchscreen to work.
My dts
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun8i-h3";
	fragment@0 {
		target = <&pio>;
		__overlay__ {
			spi1_cs1: spi1_cs1 {
				pins = "PC11";
				function = "gpio_out";
				output-high;
			opiz_display_pins: opiz_display_pins {
				pins = "PC9", "PC6", "PC5";
			ads7846_pins: ads7846_pins {
				pins = "PH6";
				function = "irq";
	fragment@1 {
		target = <&spi1>;
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			pinctrl-1 = <&spi1_cs1>;
			pinctrl-names = "default", "default";
			cs-gpios= <0>, <&pio 2 11 0>; /* PH9 PC11 */
                        opizdisplay: opiz-display@0 {
                                reg = <0>; /* Chip Select 0 */
                                compatible = "ilitek,ili9341";
                                spi-max-frequency = <16000000>;
                                status = "okay";
                                pinctrl-names = "default";
                                pinctrl-0 = <&opiz_display_pins>;
                                rotate = <90>;
                                bgr = <0>;
                                fps = <10>;
                                buswidth = <8>;
                                dc-gpios = <&pio 2 6 0>;      /* PC6 */
                                reset-gpios = <&pio 2 9 1 >; /* PC9 */
                                led-gpios=<&pio 2 5 0>;      /*  PC5 */
                                debug=<0>;
			ads7846: ads7846@1 {
				reg = <1>; /* Chip Select 1 */
				compatible = "ti,ads7846";
				spi-max-frequency = <500000>;
				status = "okay";
				pinctrl-0 = <&ads7846_pins>;
				interrupt-parent = <&pio>;
				interrupts = <7 6 2>; /* PH6 IRQ_TYPE_EDGE_FALLING */
				pendown-gpio = <&pio 7 6 0>; /* PH6 */
				/* driver defaults, optional */
				ti,x-min = /bits/ 16 <0>;
				ti,y-min = /bits/ 16 <0>;
				ti,x-max = /bits/ 16 <0x0FFF>;
				ti,y-max = /bits/ 16 <0x0FFF>;
				ti,pressure-min = /bits/ 16 <0>;
				ti,pressure-max = /bits/ 16 <0xFFFF>;
				ti,x-plate-ohms = /bits/ 16 <400>;
14 часов назад, Peter Gregory сказал:
orange-pi-pc-hdmi-lcd-mpi3508-touchscreen-spi-move-cs-from-pin-24-to-pin-22
You have just set up this touchscreen display for another device. This is a fact.
See the schematic diagram for this new device.
Perhaps SPI1 is already divorced on the board and connected to the memory chip?
Use my suggestions and do it by analogy. I'm sure you can handle it.
  • Author
Yeah, I think you are right.  I got the device working on an Orange PI PC, but I wanted a lower cost board with wifi.  I thought I could use the same technique to get the display working on my Orange PI Zero 2, but I couldn't find any pins I could use to drive the display.  The device tree allocated all the exposed pins for other uses.  Has anyone had luck getting a display like this one working on an Orange PI Zero W2 or similar hardware?
11 часов назад, Gunjan Gupta сказал:
@Peter GregoryAre you sure you are using the right pins? Based on the schematics, SPI1
@Gunjan Gupta You are, as always, the very courtesy!
Provided a link to the documentation.
From which follows:
26 pins | pin name | function  |
  3     |    PH5   | spi1-cs0 ?|
 19     |    PH7   | spi1-mosi |
 21     |    PH8   | spi1-miso |
 23     |    PH6   | spi1-clk  |
 24     |    PH9   | spi1-cs0 ?|
 26     |    PC10  | spi1-cs1  |
But this scheme says that the pins are divorced somewhere else. GPIO ASSIGNMENT (4)
The first thing that came to my mind was to take a soldering iron in my hands and .....
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
