Skip to content
View in the app
Armbian Community Forums
  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
All Armbians with Kernel 6.8.x woun't start on Radaxa Rock 5b
Featured Replies
Hi,
I have tried Rock 5b images with Kernel 6.8.10. Any of image I've tested will not start.
No LED flashing, no HDMI signal.. nothing.
The others with Kernelย 6.1.43 starts fine.ย
Solved by Tomogo
  • Author
  • Solution
Hi,
I hate you (sorry just joke)ย ๐Ÿ™‚
ย
I have no UART to USB cable so I found old Teensy 3.2 board. Made program for Serial to USB bridge.
Updated SPI flash with new firmware with debug mode.
And....
ย
It works now! Dam or huray... ๐Ÿ˜‰
ย
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
Manufacturer ID:0x6
CH0 RX Vref:27.5%, TX Vref:25.8%,25.8%
CH1 RX Vref:25.8%, TX Vref:25.8%,25.8%
CH2 RX Vref:27.9%, TX Vref:24.8%,24.8%
CH3 RX Vref:27.1%, TX Vref:24.8%,24.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28)
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MTD2
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK
## Checking uboot 0x00200000 ... sha256(25a398ffe0...) + OK
## Checking fdt 0x0031e9f8 ... sha256(5bee414074...) + OK
## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK
## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 489.724/719.766 ms
ย
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45
NOTICE: BL31: Built : 10:11:21, Dec 27 2023
INFO: spec: 0x1
INFO: code: 0x88
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: l3 cache partition cfg-0
INFO: system boots from cpu-hwid-0
INFO: disable memory repair
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
ย
ย
U-Boot 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28 +0800)
ย
Model: Radxa ROCK 5B
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfeb50000
DRAM: 16 GiB
Sysmem: init
Relocation Offset: eda3f000
Relocation fdt: eb9f96c0 - eb9fecc8
CR: M/C/I
Using default environment
ย
DM: v2
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(assign): mmc 0
MMC0: HS400 Enhanced Strobe, 200Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
Failed to load DTB, ret=-2
No valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
MPIDR: 0x81000000
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 24000 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 24000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
pcie@fe150000: PCIe Linking... LTSSM is 0x0
pcie@fe150000: PCIe Linking... LTSSM is 0x6
pcie@fe150000: PCIe Linking... LTSSM is 0x210023
pcie@fe150000: PCIe Link up, LTSSM is 0x230011
pcie@fe150000: PCIE-0: Link up (Gen3-x2, Bus0)
pcie@fe150000: invalid flags type!
ย
Device 0: unknown device
ย
Device 1: unknown device
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3920 bytes read in 8 ms (478.5 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0:1
172 bytes read in 8 ms (20.5 KiB/s)
26373283 bytes read in 112 ms (224.6 MiB/s)
32436736 bytes read in 142 ms (217.8 MiB/s)
163397 bytes read in 28 ms (5.6 MiB/s)
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
No misc partition
## Loading init Ramdisk from Legacy Image at 0a200000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 26373219 Bytes = 25.2 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
reserving fdt memory region: addr=8300000 size=8e000
Using Device Tree in place at 0000000008300000, end 0000000008390fff
can't found rockchip,drm-logo, use rockchip,fb-logo
WARNING: could not set reg FDT_ERR_BADOFFSET.
failed to reserve fb-loader-logo memory
Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000)
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000)
Total: 2321.467/3095.859 ms
ย
Starting kernel ...
ย
ย
Kernel 6.8.y is hit and miss. We need to separate download links somehow ... for now it was added "Kernel 6.8.y is at experimental support level! Not all features work but it runs fairy stable." to warn you. Its good to be there, as they are usable - where they work. I run several github runners on Rock5 without any troubles for months.
Account
Navigation
Search
Search
Chrome (Android)
  2. Tap Permissions โ†’ Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
