August 16, 20251 yr Hello! Is there a possibility to change the default LED0 behaviour of the RTL8201F PHY? Here is the Datasheet: https://file.elecfans.com/web1/M00/99/0F/o4YBAF0VytaAI7ezABH66fmIRIg854.pdf?filename=RTL8201F-VB-CG.pdf And this is the relevant register: It states, that "11" is the default - but I think it is changed to "00" during driver initialization - is that possible? I would like to change it to "01" - is this somehow possible without recompiling the driver? Thank you! Best regards, Manuel Edited August 16, 20251 yr by mm2189
August 16, 20251 yr I'm sure it is possible. I'd be happy to test your patch and submit it so it becomes part of the standard Armbian distro image. - brent
August 16, 20251 yr Author Hello brent, have you got a hint, on how it could be done? Best regards Manuel
