Skip to content
View in the app
Armbian Community Forums
Featured Replies
  • Author
9 hours ago, 晓飞丁 said:
Is FEX or DXVK 1.7.1 is a must ?
Yeah, mb box64 issue or something. I can't boot this game with box64 + wine/proton, only hangover (FEX) is working for me.
Any Dxvk will work, I think!
Thank you so much!
I try FEX today and it is the same. I will try hangover tomorrow
  • Author
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115)
+ PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco)
+ box64 3.9 (https://ryanfortner.github.io/box64-debs/)
+ proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz)
+ DXVK-stripped v2.1
>=60fps@720p
NineSols
Edited by KhanhDTP
  • Author
+ DXVK-stripped v1.7.1
~30fps@720p
Metal Gear Solid Ground Zeroes
Edited by KhanhDTP
  • Author
+ wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14)
+ DXVK-stripped v1.10.3
40~60fps@1080p
Persona 4 Golden
Edited by KhanhDTP
  • Author
8 minutes ago, Werner said:
Are you sure you don't mean BSP which stands for Board Support Package??
Ah, yes, mb. I will edit the messages.
  • Author
+ dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases)
+ DXVK-stripped v1.6.1
~60fps@720p
Noted:
. The DX9 version of the game is black-screen.
. The DX10 version works. However, it will crash immediately after the tutorial stage because the PanVk driver still lacks the "Geometry Shaders" feature.
. By using dgVoodoo2, the DX9 black screen issue was fixed.
Devil May Cry 4 (DX9 + dgVoodoo2 + DXVK)
Devil May Cry 4 (DX10)
Edited by KhanhDTP
  • Author
 + wine-9.22-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/9.22)
~40fps@720p (Ultra High settings)
Oblivion
  • Author
~60fps@720p
Need For Speed Most Wanted
NFS-Most-Wanted-Original--PanVk@720p(1).thumb.jpg.664c04ba5264c5526401bfee4cb06b9e.jpg
  • Author
+ wine-10.20-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.20)
~60fps@720p (Medium settings)
box64 environment variables:
Quote
export BOX64_DYNAREC_BIGBLOCK=3
export BOX64_DYNAREC_FORWARD=512
export BOX64_DYNAREC_CALLRET=1
Prince of Persia - The Forgotten Sands
  • Author
+ DXVK-stripped v2.6.2
30~60fps@720p
Quote
Need for Speed Hot Pursuit
  • Author
~60fps@720p
Quote
Call of Duty 2
Edited by KhanhDTP
~60fps@720p
How did you apply dgVoodoo2 ? I download the archieve file it is a bunch of dll.
  • Author
You can download dgVoodoo2 from here: https://community.pcgamingwiki.com/files/file/572-dgvoodoo-2/
(Unfortunately, newer versions of dgVoodoo2 won't work with Wine/Proton.)
Extract the archive, then copy dgVoodoo2_79_1/MS/x86/d3d9.dll to the game's folder (just like Dxvk).
Then, copy the Dxvk's d3d11.dll, dxgi.dll to the game's folder.
If done right, you will see that the Dxvk HUD shows the game uses D3D11 API.
Great! Thanks a lot! I will try it to se if Diablo II can run tonight!
  • Author
+ box64 4.1 (https://ryanfortner.github.io/box64-debs/)
+ DXVK-stripped v2.1 (more likely to be crash-proof than other Dxvk versions)
~40fps@720p (Medium settings)
(There are small graphics are flickering. Locking the FPS at 30fps seems to fix it a bit)
Quote
# export BOX64_DYNAREC_SAFEFLAGS=2; export BOX64_DYNAREC_STRONGMEM=1 # Add these if you face random crashes
Prince of Persia 2008
  • Author
~60fps@720p (Medium/High settings)
Quote
Need for Speed - Underground 2
  • Author
+ Box64 arm64 v0.4.1 2eb2fd9cd (https://ryanfortner.github.io/box64-debs/)
+ wine-11.0-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/11.0)
+ DXVK-stripped v2.4.1
40~60fps@720p (low settings + high texture setting)
Quote
Bioshock
  • Author
30~60fps@720p (medium settings)
Quote
export BOX64_DYNAREC_FORWARD=256
Batman Arkham Asylum GOTY
Edited by KhanhDTP
On 12/28/2025 at 3:05 PM, KhanhDTP said:
Persona 4 Golden
Cool! I own this game as well, just didn't test it as I thought atlus put most their games under DRM. Definitely going to try it later.
Also found that some games (probably CPU-intensive ones) work better on hangover compared with box64+proton/wine, if only the game was compatible.
@robertojTheoretically it will, as H618 supports OpenGL and Vulkan. But do not expect the same performance as RK3588.
This is off the topic here and you'd better ask someone who share the same chip with you.
  • Author
+ Box64 arm64 v0.4.1 3ec5de03c (https://ryanfortner.github.io/box64-debs/)
15~60fps@720p
Quote
export BOX64_PREFER_EMULATED=1
FF13 Lightning Returns
Edited by KhanhDTP
  • Author
50~60fps@720p (medium/high settings)
Quote
F.E.A.R. Platinum Collection
Edited by KhanhDTP
  • Author
+ Box64 arm64 v0.4.1 72807b6b9 (https://ryanfortner.github.io/box64-debs/)
~60fps@1080p (no AA)
Quote
FlatOut Enhanced
  • Author
50~60fps@1080p (no AA)
Quote
FlatOut 2 Enhanced
  • Author
30~40fps@720p (low settings, high texture, no AA)
Quote
FlatOut - Ultimate Carnage
Edited by KhanhDTP
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
