Skip to content
View in the app
Armbian Community Forums
Rock5b: onboard FAN - how can this be adjusted?
Featured Replies
Hi,
i think the rpm setting-step's of the onboard fan is to low.
SBC: Rock5b
Edited by rolsch
  • Author
I think the onboard fan is not being controlled correctly.
root@rock5b01:~# dmesg | grep -i fan
[    6.577344] pwm-fan pwm-fan: Looking up fan-supply from device tree
[    6.577352] pwm-fan pwm-fan: Looking up fan-supply property in node /pwm-fan failed
[    6.581563] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22
[    6.581571] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22
[    6.581574] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22
[    6.581577] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22
Running:  Armbian v25.11.2 for Rock 5B running Armbian Linux 6.1.115-vendor-rk35xx
On my Rock5 ITX I am currently manually setting fan speed using commands like :
echo 32 | tee /sys/devices/platform/pwm-fan/hwmon/hwmon12/pwm1
bump numbers to 64/128/256 for higher speeds. Change the hwmon/hwmon* number to match what your OS uses ...
Sometimes the machine boots with 100% fan speed that does now slow down after full boot and I have to manually set it like this. At other times it boots up normally  with low fan speed.
Not sure why Armbian does not use sensors by default to scale fan speeds automatically based upon temperature. But later this week I will add the script before I start applying more load/apps to my system.
Edited by Raul
added more comments
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
