April 1Apr 1 I finally successfully got Armbian installed on my Pinebook Pro's eMMC. That should be giving it its best possible performance. I thought you may all be interested in compiling a list of games that work at least reasonably well on it given its restrictions of being ARM64 architecture, 1.8GHz CPU & 4GBs RAM. So to start here is a list of the ones I currently have on mine. I may try more later but for now I'm limited by the stock 64GB eMMC that the PCP came with... 0AD - 3D RTS Cave Story - Pixel Art Metroidvania Dr Robotnik's Ring Racers - Kart Racer Dune Legacy - RTS Endless Sky - Space Sandbox Flare - Fantasy RPG Freeciv - Strategy Freecol - Strategy GZDoom - Doom Engine for Mods & Total Conversions Hedgewars - Worms "Homage" Neverball - Monkeyball "Homage" Neverputt - Miniputt Golf Game Open Fodder - FOSS Engine for "Cannon Fodder" OpenRA - FOSS RTS Engine for "Tiberian Dawn", "Red Alert" & "Dune 2000" Open TTD - Transit Management Sim OpenTyrian - FOSS Engine for Top-Down Shmup "Tyrian" Perfect Dark - PC Port of N64 Game with Keyboard/Mouse Support Pico-8 - Indie Pixel Art Gaming & Development Platform Pingus - Lemmings "Homage" ScummVM - FOSS Engine for Classic Point & Click Games Sonic Robo Blast 2 - 3D Platformer The Ur-Quan Masters - FOSS Port of Space Sandbox "Star Control II" Xonotic - Arena Shooter FPS There are other games I have not yet personally tried like OpenHV, SuperTuxKart, other emulators etc but if anyone can confirm they work reasonably well on the Pinebook Pro then please let the rest of us know. All ScummVM games I've tried from King's Quest I to Grim Fandango work perfectly. However GZDoom will struggle with especially demanding modern Doom mods like Trenchfoot, Auger Zenith, Inquisitor III, Godless Nite etc. but most like Aliens: Eradication, Ashes 2063/Afterglow, Brutal Doom, Castlevania: Simon's Destiny, Irontusk's Diablo 3D, Revenge of the Triad etc run just fine. Edited April 1Apr 1 by Katsujinken
April 2Apr 2 PSP emulation with PPSSPP should work for a lot of games. It's a pity we never got a fully working Vulkan driver. God of War is probably too much. At least it was when I tested it many years ago.
April 3Apr 3 Author Ooh interesting! The PBP in your video is using Manjaro though, can PPSSPP compile on Armbian? Perfect Dark aside, I haven't had any luck compiling other supposedly ARM64 compatible software like 2Ship2Harkinian etc through Armbian. If we can figure it out then maybe GoW will also be more playable on PBP through its own eventual native PC Port.
April 4Apr 4 My PBP died, so I can no longer test it myself. You can start by testing the PPSSPP aarch64 AppImage. https://github.com/hrydgard/ppsspp/releases A couple of years ago I had performance issues with the PPSSPP Flatpak on my Phytium D2000, so I built it on Ubuntu 22.04. I'm not sure if I followed the instructions for Qt, or for Linux. So you need to install the prerequisites and I guess it doesn't hurt to install the additional packages mentioned for Ubuntu. https://github.com/hrydgard/ppsspp/wiki/build-instructions#building-with-cmake-other-platforms-eg-linux
May 20May 20 Author Updating to include a few more I've successfully run... OpenMW - FOSS Engine to play Morrowind & it's KOTOR total conversion Starwind Quakespasm - FOSS engine to play Quake and it's expansions, mods & total conversions UFO: Alien Invasion - an XCom "homage" Yamagi Quake 2 - FOSS engine for Quake 2 I was able to test Quake Mods like the cyberpunk FPS prequel to a prequel to a Dreamcast mecha game "Slave Zero X: Enyo" and top down fantasy RPG "Prydon Gate". Both work great but I'll need to upgrade the eMMC before I can try larger sized conversions like Brutalist Jam III or Slayer's Testaments.
May 21May 21 Did you try Yamagi Quake 2 with OpenGL ES1? A developer optimized it, and I assume it will also be a lot faster on a PBP, but it might be that certain mods don't work with GLES1. You have to build it like this: make -j4 WITH_SDL3=no with_gles1 Select OpenGL ES1 in the Video Settings. If you don't see blood particles (or they are squares), go to the game console and disable a certain module: gl1_pointparameters 0 Restart the game and have fun!
May 27May 27 Author Oh I just downloaded Yamagi from Snap but OpenGLES was glitchy so I switched the settings to OpenGL 1.4 and it works great so I don't especially want to risk what might happen if I switch it to OpenGL 3.4 lol I also gave eduke32 a try and the flatpak version would launch Duke3D, Ion Fury, BloodCM, etc but have sound & no video despite what resolution I set it to or if it was on OpenGL vs Software. So I compiled the eduke32 mobile version which will launch my Duke Nukem 3D Plutonium Edition's duke3D.grp but give a CON file compilation error when I try those other build engine games.
May 27May 27 Perhaps you can try to build Yamagi from source, as I pointed out, a developer has really optimized OpenGL ES. Here you can see it on a VisionFive 2, RISC-V SBC, hitting almost 200fps at 1080p! You can also try PS1 emulation with PCSXR (works without PS1 BIOS). I assume it's just: sudo apt install rpcsx .If you have a PS1 BIOS, you can also try Duckstation. If you need a game for testing, you can try Magic Castle. It was released for free. http://netyaroze.com/Media/Magic-Castle https://archive.org/details/magic-castle-2021-07-may Regarding eDuke32, did you try disabling compressed textures? Quote Note2: Some recent (G33 for example) Intel graphics cards work with OpenGL mode if texture compression is disabled (r_texcompr "0", see settings.cfg configuration file). https://wiki.eduke32.com/wiki/Frequently_Asked_Questions
June 17Jun 17 Oh man, every Armbian install to Pinbook Pro's eMMC I heard of always ended up failing. Which steps did you do to successfully install Armbian to your eMMC? Would really appreciate it!
