Skip to content
View in the app
Armbian Community Forums
Gpu driver
Featured Replies
Hi! I've successfully installed Armbian Bionic(kernel 4.20, automated build)  image on NanoPC-T4, but gpu drivers not provided.
Here output of
sudo armbianmonitor -u
http://ix.io/1FBI
And /dev/mali0 didn't exist.
The question is: how to build and install open-source drivers(I didn't find any complete instructions), I actually not so experienced on it.
Edited by iamlion12
You can use the Media Scipt from JMCC for imporvements in video playback, and making opengl possible.
Please read the radme file for more info.
  • Author
39 minutes ago, Igor said:
Wait a year that things are developed and gets to the user levels. Until then, use kernel 4.4.y
I don't have possibility "to wait a year" neither use 4.4 kernel.
I can't use 4.4 kernel because I use opencl for computitions and this kernel tends to be slow with RAM. But 4.18+ kernel shows better results (firefly 3399).
Could you give more sensible advice how to get mali gpu driver working if you please?
Should that be my/our problem?
"The bearer of bad news should not be held accountable for it."
Armbian project doesn't provide on-demand solutions solving. You are on your own - join development and you will eventually collect needed information/advice/hints and when dependencies are solved and matured you will be able to achieve this. Check also what supported means.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
