Skip to content
View in the app
Armbian Community Forums
RK3399 Legacy Multimedia Framework
Featured Replies
  • Author
3 hours ago, Дмитрий Батин said:
Do you have any manual, that can help us to get it ?
Hello! In the first post, you have links to all the sources, most of them from my GitHub repos. The procedure might be outdated, though, I haven't touched it since 2019.
For Kodi, you can try the rockchip branch for legacy kernel, or the mainline branch for current. Compilation instructions are included in the repo. Good luck!
  • Igor unpinned this topic
I installed this image to my rockpro64: https://mirror.yandex.ru/mirrors/armbian/archive/rockpro64/archive/Armbian_21.05.4_Rockpro64_buster_legacy_4.4.213.img.xz
Installation & automatic booting into KODI works perfectly. In addition, playing h264 encoded video files also played with HW acceleration, playback is smooth, HDMI have audio.
The problem is h265 videos. They are stuttering periodically (every 2 seconds ) with all the TVs I tested.
Does anybody know a solution to this?
@JMCC Also, is it possible to have a :
HW accelerated decoding with smooth h264 / h265 playback
- HDMI audio
- Automatic booting into kodi
on the latest upstream builds of Armbian for Rockpro64  ?
Note: I tested LibreElec for Rockpro64 and all above works perfectly. The problem with LibreElec is its rootfs: It is not Debian / ubuntu and I need to be able to install my packages there, so my use-case is best of both worlds.
Recommended way to get this running on a headless system?
My end goal is to get HW acceleration working for transcoding using Jellyfin 10.9 (which now supports rkmpp) on my RockPi4a . So I tried to make a new install on an SD card following the directions here. BUT, I didn't install the desktop legacy buster image, I tried Armbian_21.05.1_Rockpi-4a_buster_legacy_4.4.213 instead.
During
Quote
sudo apt update && sudo apt upgrade
I got an error
Quote
Err:6 http://deb.debian.org/debian buster-backports Release
  404  Not Found [IP: 199.232.30.132 80]
And
Quote
Unable to locate package media-buster-legacy-rk3399
I'm missing several of the devices listed on the Jellyfin RKMPP page, most notibly rkvenc, dma_heap, mpp_service (but maybe that is just because I'm using a rk33xx chip)
Is the desktop image necessary to get all the devices for rkmpp to work?
sudo armbianmonitor -u is generating an error for me. Is there a different way now to upload this info?
40 minutes ago, Werner said:
Buster, kernel 4.4.y and therefore this multimedia framework are deprecated.
I get that, this is the Legacy multimedia framework afterall. But as far as I am aware this is the only set up that supports the HW accel chips in RK3399. So it has the only chance of work there might be.
But I can't even get media-buster-legacy-rk3399 to install at the moment. Just looking for some guidance if this is related to not using the desktop image, or if it's because of the missing repo I mentioned.
  • Werner unfeatured this topic
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
