Skip to content
View in the app
Armbian Community Forums
Kodi for rk35xx 5.10 legacy kernel
Featured Replies
Rockchip has released bsp kernel 5.10 for rk356x and rk3588. Since multimedia support is not fully supported by mainline kernel, a legacy kernel would be good if you want h264/hevc hardware decode.
To make kodi support hardware decoding, you need:
1, ffmpeg supporting rkmpp. I've packaged it in my ppa: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia, which is based on the patch from https://github.com/JeffyCN/FFmpeg/.
2, kodi built with gles render system, which is also in my ppa
3, a gpu driver supporting gles. For rk356x you can use mainline panfrost driver. For rk3588 you can use panfork-mesa from my ppa: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/panfork-mesa
I've tested that kodi can support hardware decoding on both 3568 and 3588. Here is the steps for rock5b to install kodi:
1, download the image I build with panfork-mesa and malig610 firmware: https://github.com/amazingfate/armbian-rock5b-images, and install it on your rock5b.
2, add my rockchip multimedia ppa: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia:
    sudo add-apt-repository ppa:liujianfeng1994/rockchip-multimedia
3, create a udev rule to enable the permission ofrockchip's mpp device:
KERNEL=="mpp_service", MODE="0660", GROUP="video"
KERNEL=="rga", MODE="0660", GROUP="video"
KERNEL=="system-dma32", MODE="0666", GROUP="video"
KERNEL=="system-uncached-dma32", MODE="0666", GROUP="video" RUN+="/usr/bin/chmod a+rw /dev/dma_heap"
    wirte the above rules to /etc/udev/rules.d/11-rockchip-multimedia.rules
4, install kodi:
    sudo apt install kodi
5, move kodi from xsession to wayland-session:
    sudo mv /usr/share/xsessions/kodi.desktop /usr/share/wayland-sessions/kodi-wayland.desktop
6, reboot the board:
    sudo reboot
7, in the lightdm greeter, select kodi and login
8, After starting kodi, in Settings -> Player -> Videos, enable "Allow using DRM PRIME decoder" and "Allow hardware acceleration with DRM PRIME". And set "PRIME Render Method" to "Direct To Plane"
9, Then you can play h264/h265 8 bit/10bit videos up to 4K.
============Updated on 20230206===================
rockchip-multimedia has become a universal ppa for rockchip legacy kernel. Here is the introduction: https://forum.radxa.com/t/introduction-to-rockchip-multimedia-ppa-for-ubuntu-jammy/14537
I provide a new package rockchip-multimedia-config to do all the system configs such as udev rules, chromium v4l2 devices creation. Just install this package and reboot, you are good to go.
  • Author
I've created an issue about 10 bit videos not playable on kodi: https://github.com/xbmc/xbmc/issues/22202.
Here is the debug log of kodi: https://paste.ubuntu.com/p/C29gywz4Tg/. We can see "CEGLImage::SupportsFormat - format not supported: NA12". NA12 should come from ffmpeg: https://github.com/JeffyCN/FFmpeg/blob/master/libavcodec/rkmppdec.c#L48. What I concern is why the support list of dma buf format doesn't have NV15, the yuv420 10bit drm format, which should be supported by the rockchip's drm driver: https://github.com/friendlyarm/kernel-rockchip/blob/nanopi5-v5.10.y_opt/include/uapi/drm/drm_fourcc.h#L244. Kodi uses eglQueryDmaBufFormatsEXT to get the supported dma buf format: https://github.com/xbmc/xbmc/blob/master/xbmc/utils/EGLImage.cpp#L225.
Anyone knows why egl doesn't support 10 bit drm format NV15?
@jernej@Kwiboo@balbes150
NV15, although sounds standard, it's not. It's RK invention and used only (AFAIK) on their chips. So I would presume not many mesa developers are aware of it and even less care about it. Note, EGL has nothing to do with DRM planes. EGL lists format supported for GPU rendering and DRM planes lists formats supported by Direct to plane rendering. There is catch, though. ffmpeg must provide proper mapping to DRM descriptor. I have no idea if that's done for NV15 in ffmpeg rkmpp module. If that's not done, direct to plane method won't work.
Note that I don't care about vendor solutions and I'm only indirectly involved with RK platforms, so I can't help you more.
I tried your image for the rock pi 3a and followed all other instructions to get ffmpeg. I get the following when running this:
ffmpeg -i rtsp://... -f webm -r 20 -s 640x400 -vcodec vp8 clip1.webm
[h264_rkmpp @ 0xaaab1b1af850] Failed to initialize MPP context (code = -1).
[h264_rkmpp @ 0xaaab1b1af850] Failed to initialize RKMPP decoder.
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (h264_rkmpp) -> vp8 (libvpx))
  Stream #0:1 -> #0:1 (pcm_alaw (native) -> opus (libopus))
Error while opening decoder for input stream #0:0 : Unknown error occurred
Do you have any idea where I am doing something wrong?
okay thanks already I thought that because you posted in the rock 3a forum it would be available for rock 3a as well. Please let me know if you have made it available I would be happy to help you test.
hi amazingfate, you know, i have problems with my android tv H96 max v58 (rk3588) to decode h265 1080p 10 bit video files (8bit perfect). I ve tested with a lots of videos and only with that specification presents a green screen and glitches when decode with kodi's (or vlc's) hardware acceleration. The most weird of all its that i don't have any glitch with 2160p 10bit video files, it's very strange, You have any solution for this? thanks
I have flashed your image to SD card using Etcher. The blue LED is blinking and it looks like the board is doing something. But there is no signal on the HDMI port, nor can I access the board via SSH. I have specially connected a strong power supply and did not use NVMe. What else could it be? I could boot a "standard" Debian 11 (CLI, without a desktop).
What can this be?
I solved the booting problem by using a weak 5V 2A power supply!
Then I installed everything according to your instructions. In KODI itself there are not the described options in the VIDEO Settings (Settings -> Player -> Videos, enable "Allow using DRM PRIME decoder" and "Allow hardware acceleration with DRM PRIME"). Also not around "Expert" mode.
What am I missing here?
So once again switched to Wayland and...: The settings are visible!
All settings made according to amazingfate!
Then downloaded a sample video (h.264 UHD + another sample in 1080p) and added it to the MOVIE library.
-> For both videos neither picture nor tone! The progress bar is visible and the screen is gray.
(Oh, I have now (re-)changed the power supply for an ANKER 30W, runs well)
@amazingfate Hi,  Thank you very much for your work.
I'm having trouble installing a ppa.
Err:18 https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu kinetic Release
  404  Not Found [IP: 2620:2d:4000:1::3e 443]
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu kinetic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Share a link to the repository with Makefile , for a self-build kodi with mpp.
https://github.com/amazingfate/armbian-compile-action/blob/main/action.yml
It is also not clear what prevents you from pouring your patches for the kernel into the main armbian branch?
I noticed some of your patches
https://github.com/armbian/build/pull/4540
Edited by whitefox
kodi successfully decodes UHD (4K) and FullHD (1080p, 720p) video. But there are some problems with non-standard dimensions like 720x396 - green frames are displayed.
"ffplay -vcodec h264_rkmpp" successfully plays such video.
OK, I dealt with my problem.
If kodi started from Gnome Ubuntu session then no "PRIME Render Method" option available.
So kodi must be started as standalone session, then non-standard dimension video is displayed properly.
Also if kodi-standalone started from ssh, then video is played properly. But if kodi-standalone started from terminal in Gnome session then again the same problem (and no "PRIME Render Method" option).
Edited by sergei_gagarin
rock3a is not supported by now because my image hasn't get legacy kernel 5.10 support. But I've just supported another rk3568 board hinlink h68k: https://github.com/amazingfate/armbian-h68k-images. I will make support for rock3a someday in the future.
Is the only difference device tree? Could I use h68k image on rock 3a but replace the dtb before booting it? If so get dtb from one of radxa images of 5.10?
Hi @amazingfate
I managed after long struggle to get GPU video decoding to work on a Rock 5b with Kodi. However I came to the same problem with HEVC (H265) when using 10bit. Black image and the errors in Kodi Log:
2023-02-20 14:29:51.144 T:5166     INFO <general>: Creating InputStream
2023-02-20 14:29:51.352 T:5166     INFO <general>: Creating Demuxer
2023-02-20 14:29:51.528 T:5166     INFO <general>: Opening stream: 0 source: 256
2023-02-20 14:29:51.528 T:5166     INFO <general>: Creating video codec with codec id: 173
2023-02-20 14:29:51.528 T:5166     INFO <general>: CDVDVideoCodecDRMPRIME::Open - using decoder hevc (rkmpp)
2023-02-20 14:29:51.529 T:5166     INFO <general>: Creating video thread
2023-02-20 14:29:51.529 T:5173     INFO <general>: running thread: video_thread
2023-02-20 14:29:51.530 T:5166     INFO <general>: Opening stream: 1 source: 256
2023-02-20 14:29:51.530 T:5166     INFO <general>: Finding audio codec for: 86060
2023-02-20 14:29:51.530 T:5166     INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder truehd
2023-02-20 14:29:51.530 T:5166     INFO <general>: Creating audio thread
2023-02-20 14:29:51.530 T:5174     INFO <general>: running thread: CVideoPlayerAudio::Process()
2023-02-20 14:29:51.530 T:5166     INFO <general>: Opening stream: 4 source: 256
2023-02-20 14:29:51.541 T:5174     INFO <general>: Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, no pass-through)
2023-02-20 14:29:51.541 T:1874     INFO <general>: CActiveAESink::OpenSink - initialize sink
2023-02-20 14:29:51.563 T:1859    ERROR <general>: CEGLImage::SupportsFormat - supported formats:
2023-02-20 14:29:51.563 T:1859    ERROR <general>: CEGLImage::SupportsFormat -   AB4H
2023-02-20 14:29:51.564 T:1859    ERROR <general>: CEGLImage::SupportsFormat -   NV12
2023-02-20 14:29:51.564 T:1859    ERROR <general>: CEGLImage::SupportsFormat -   NV16
2023-02-20 14:29:51.564 T:1859    ERROR <general>: CEGLImage::SupportsFormat -   Y210
2023-02-20 14:29:51.564 T:1859    ERROR <general>: CEGLImage::SupportsFormat -   Y212
2023-02-20 14:29:51.564 T:1859    ERROR <general>: CEGLImage::SupportsFormat -   Y216
2023-02-20 14:29:51.564 T:1859     INFO <general>: GLES: Selecting single pass rendering
2023-02-20 14:29:51.564 T:1859     INFO <general>: GLES: Selecting YUV 2 RGB shader
2023-02-20 14:29:51.564 T:1859    ERROR <general>: CBaseRenderer::GetShaderFormat - unsupported format 181
2023-02-20 14:29:51.564 T:1859    ERROR <general>: GLES: BaseYUV2RGBGLSLShader - unsupported format 0
2023-02-20 14:29:51.606 T:1859     INFO <general>: Skipped 1 duplicate messages..
2023-02-20 14:29:52.220 T:1874     INFO <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 199 ms Periodsize 50 ms
I did see on your Github Issue that you fexed it, but I didn't find how. Or maybe that's something else?
On 1/28/2023 at 3:49 PM, amazingfate said:
For rk3588
Hi @amazingfate
Does your ppa:liujianfeng1994/rockchip-multimedia repo widevinecdm still work?
I'm running Armbian 23.08.0 Jammy with Linux 5.10.160-rk35xx on Opi5+
I installed your rockchip-multimedia-config, and  kodi kodi-inputstream-adaptive libnss3
I'm trying to get some NZ streaming services to work on Kodi, but inputstream.adaptive errors with 'Unable to load widevine shared library (/home/kschwar3/.kodi/cdm/libwidevinecdm.so)'.  The libwidevinecdm.so file from your repo exists in that location.
The Chromium browser also fails on these streaming services. I tried reinstalling chromium-browser, libc-bin and libc6 from your repo.
16 minutes ago, amazingfate said:
Thanks @amazingfate  Yes that's a good blog.
I've got both services working on Chromium.   They must be similar to Netflix.
They didn't like the user-agent and when I changed to the Chromebook user-agent, they worked.
Hopefully Kodi will also be a simple fix.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
