Skip to content
View in the app
Armbian Community Forums
Orange Pi 5 Plus - No Sound
Featured Replies
Installed: Armbian_23.11.1_Orangepi5-plus_bookworm_edge_6.7.0-rc1
The analog device is visible, but there's no sound from the headphone jack.
The hdmi device is not visible.
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Analog [Analog], device 0: fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
There is no sound when I play a test file:
aplay -D hw:0,0 /usr/share/sounds/alsa/Noise.wav
Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
aplay: set_params:1358: Channels count non available
I've looked in the journal log but nothing stands out to me.
Sound doesn't appear to be muted, I added amixer output below.
What do I do next?
amixer output:
Simple mixer control 'PCM',0
  Capabilities: volume
  Playback channels: Front Left - Front Right
  Capture channels: Front Left - Front Right
  Limits: 0 - 192
  Front Left: 192 [100%] [0.00dB]
  Front Right: 192 [100%] [0.00dB]
Simple mixer control 'Mic PGA',0
  Limits: 0 - 8
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Capture Digital',0
  Limits: 0 - 192
  Front Left: 0 [0%] [-96.00dB]
  Front Right: 0 [0%] [-96.00dB]
Simple mixer control 'Capture Polarity',0
  Capabilities: enum
  Items: 'Normal' 'L Invert' 'R Invert' 'L + R Invert'
  Item0: 'Normal'
Simple mixer control 'Capture ZC',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [off]
Simple mixer control 'DAC Deemphasis',0
Simple mixer control 'Differential Mux',0
  Capabilities: enum
  Items: 'Line 1' 'Line 2'
  Item0: 'Line 1'
Simple mixer control 'Left Line Mux',0
  Capabilities: enum
  Items: 'Line 1' 'Line 2' 'PGA' 'Differential'
  Item0: 'Line 1'
Simple mixer control 'Left Mixer',0
Simple mixer control 'Left Mixer Left Bypass',0
  Capabilities: volume volume-joined pswitch pswitch-joined
  Capture channels: Mono
  Limits: 0 - 7
  Mono: 0 [0%] [-15.00dB] Playback [off]
Simple mixer control 'Left Mixer Right',0
Simple mixer control 'Left Mixer Right Bypass',0
  Limits: 0 - 7
  Mono: 2 [29%] [-9.00dB] Playback [off]
Simple mixer control 'Left PGA Mux',0
  Capabilities: enum
  Items: 'Line 1' 'Line 2' 'Line 3' 'Differential'
  Item0: 'Line 1'
Simple mixer control 'Output 1',0
  Capabilities: pvolume
  Limits: Playback 0 - 36
  Mono:
  Front Left: Playback 0 [0%] [-30.00dB]
  Front Right: Playback 0 [0%] [-30.00dB]
Simple mixer control 'Output 2',0
  Mono:
Simple mixer control 'Right Line Mux',0
  Capabilities: enum
  Item0: 'Line 1'
Simple mixer control 'Right Mixer',0
Simple mixer control 'Right Mixer Left',0
Simple mixer control 'Right Mixer Left Bypass',0
  Limits: 0 - 7
Simple mixer control 'Right Mixer Right Bypass',0
  Limits: 0 - 7
Simple mixer control 'Right PGA Mux',0
  Capabilities: enum
  Item0: 'Line 1'
Simple mixer control 'Route',0
  Capabilities: enum
  Items: 'Stereo' 'Mono (Left)' 'Mono (Right)' 'Digital Mono'
  Item0: 'Stereo'
Edited by octal8
Added amixer output
I'm also not seeing hdmi sound with this image:
kodi@kodi:/dev/snd/by-path$ aplay -l
  Subdevices: 1/1
I haven't tried the headphone jack, so I can't speak to whether it's working.
Currently downloading legacy so I can try that one.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
