- Installation of Proxmox VE failed
- Raspberry Pi 5 missing video decode hardware acceleration in chromium
Timezone for Iceland
- State of support for Raspberry Pi 5
- OMV builds causing problems
Nextcloudpi on Odriod N2 (and N2+): Updates impossible for nextcloud
Hi Nobi, I'm in a hurry therfore short hints for your investigation. Most info you get on matrix channel. https://matrix.to/#/!AT6qaz1QxylX2sw2mzjLElHbLKVll3kAgeIQd16e7J0/$dLsP9mV-fEjbokwdo-WqcJvg5CqsUaArfNKWWdUNPp0 Listen to the podcasts mentioned in this discussion. Yes, I have ny servers upodated to 31 and did the offered 1.55.4. update before, it is offered to running instances only (ssh boot prompt).
I have no clue of your Odroid hardware, but nextcloudpi there sudo ncp-config -> system -> info will start with an overview pi@nc-rspios5:~ $ sudo ncp-config Running nc-info Gathering information... NextcloudPi version v1.55.4 NextcloudPi image NextcloudPi_06-01-25 OS Debian GNU/Linux 12. 6.12.47+rpt-rpi-2712 (aarch64) ncp version 1.55.4 is only offered to running instances and no image is provided on github to start with. But this version offers support of nextcloud 31 which gives you some more month support, ncp maintainer is ttrying to get supprt done to nc 32. You may try sudo ncp-update and then sudo ncp-update-nc
- Problems with apt upgrade
- storage via usb plugins out of order
- Raspberry 5 - NVMe in USB-C case not detected
Armbian-unofficial_24.11.0-trunk_Rpi4b_jammy_current_6.6.78_minimal NOT FOND WIFI
Maybe country code for wifi must be set.
