Skip to content
View in the app
Armbian Community Forums
Build current and edge releases on Odroid C1
Featured Replies
Not sure if there is any link between the DietPi and Armbian building process, but the current DietPi Bookworm image for Odroid C1(+) is working fine, including
  • reboot
  • HDMI output (I have not tested X11, not sure if it is even possible)
  • USB support (I did not check hotplug, but it was a HUGE improvement over previous releases)
Dietpi is group of people (one scripting guy and two support for forums) that download images and resell under different name. There is no build process of Dietpi, there is no development. Its mainly repacking / sales of our & others work for their gain. Dietpi is a group that in 10 years of existence managed to return less then 5 fixes they found (every line is a fix of something. This is just a work into common code for past 3 months).
They never contributed in common efforts, they never return anything to people they are taking from, from us and from you. We are not alone, but hey, they compete with us, they say Debian and our work is trash, while they use numbers manipulation (kilobytes of packages on images, processes at start and similar BS) to support selling their scam. Its a shame that such projects are held accountable and being compared. We don't compare with them, but here you can see some insight https://docs.armbian.com/#key-advantages (dietpi is one of armbian downstream projects)
If our image doesn't work and theirs works, is certainly a work of randomness. How they made their image? They developed a bash script, that they use to convert / rebrand any Debian based image into Dietpi. In this process it is impossible to improve what is already broken. That is hard work, and they never did any of it. Since kernel updates are directly linked to, a copy of our packages, they are not bringing any changes ...
Images are untested, but I am sure it can't be worse then a copycat:
https://www.armbian.com/odroidc1/
Quote
Thank you. Dietpi did little to nothing. Not here and not with other devices they "support".
I know nothing about any feud or bad blood between the projects, thanks for all the background. I have no part in it and my message was not intended to laud anyone, just confirming the state of things with their latest image. Whatever DietPi packaged recently, it works. Which probably means that newer kernels have better support for Odroid C1.
Point of community open source development is sharing the load between projects.
They choose a policy to steal from open source developers. This wording can be used when they contribute nothing to commons, nothing what they do can anyone reuse. Which is a big steal in custom arm hardware world, where kernel maintenance is everything, not unlike PC world, where distros mainly represent and artistic added value. We have to loose thousands of hours to get a device up, they run a script "and support it". This type of scam only exists in open source world, as nothing is hidden. Just a moral standards or absence of them prevents people to play bad.
All our code is open and anyone can do whatever ... and there is little we can do about except informing you what is their MO. And telling you this is not something we would like to do. We would rather code, do fun stuff, cooperate, share our burdens. As sharing burden is must have in community development. The more value we generate, the better OS we make, the more they profit. By telling users how cheap hard work is, they are damaging interests and motivation of all open source developers that contribute to common efforts. Not just to Armbian. They count that you don't understand this perspective, they don't care and you will anyway forget about on day. If you invest little to nothing, little you can loose. If one have no R&D costs, if you don't maintain any infrastructure, ... Sales of somebody else work = tl;dr; diet-pi. On top of that, they were trying to offload their users complains to us. This only tells what is the level of corruption. Again you don't care who deals with the frustration you have ... Let everything hard and time consuming be pinned to the Armbian is their MO. Since ever. How one can accept such sick play?
I am sure you don't. For end users its always the same - its free stuff. And you don't care who developed it or who maintains it / keep it operational.
Its complicated to understand how Linux support for such a complex world is made. Certainly not as simple as they think and sale.
Probably, but that has nothing to do with them. All the work (on top of mainline) is inside those folders: https://github.com/armbian/build/tree/main/patch/kernel/archive
@Igor
Quote
Interested perhaps in becoming official maintainer?
I wish I could, however, sadly between my other Open Source commitments and trying to earn a living, I do not have the time. If this ever changes in future, though, I'll be sure to let you know.
Ultimately, I guess the point of my original post is that Armbian on the Odroid C1+ is currently in a good state, so great work Armbian devs! Your work is appreciated.
Edited by torz77
I think those are our common defaults ;)
We made maintaining process as simple as possible. Build system takes care of most problems already and there is even automation that prepare images for release, and once those are confirmed in good shape - USB, HDMI, .... https://docs.armbian.com/Process_CI/#prepare-standard-support-images-for-release with report similar as here https://www.armbian.com/tinkerboard/ few times per year ... that's about it. Leave your contacts https://www.armbian.com/maintainer-registry/ so we can try to contact you prior to release. if you don't have time, not a problem, perhaps someone else will cover, all this work can only be at best effort principle. Board is simply taken down from supported if status is unknown. Goal is to provide best images that build system throws out - current or edge kernel.
Small jobs always comes around and inner circle is first to know that, so its good to be around, even with this tiny role, small obligations.
I've submitted fixes to DietPi for certain boards because it seems once they become unsupported here they no longer receive bug fixes.
I know the lead guy (Michealng) has made attempts to share patches. Is there a particular process for submitting patches for Armbian?
He supports "everyting", while a team of 50 people, is unable. Who do you think is cheating here?
https://docs.armbian.com/#comparison
This is how he supports it: He download everything that is valuable from us https://docs.armbian.com/Release_Changelog/#v24111-2024-11-281000 while fixes that somehow finds the way there, they never gets here. Talking about years of work, not this particular fix.
We take support serious as we can't steal the bulk of work from someone to mitigate all sorts of troubles related to hard work (burnout, lack of food, etc.), while when you just for fun sale someone else work, this is not a problem.
https://docs.armbian.com/User-Guide_Board-Support-Rules/ A small team can only support few boards, the rest is "community supported". By you. Or by nobody.
tl;dr; If you add a fix to Armbian, he gets it, we get it. If you sent a fix to him, we don't get it.
Image for Odroid C1 is identical to ours with your fix. He doesn't add any fixes to it, besides what you provided. But its "supported" by dietpi :) Actually all important fixes in this platform was done by us https://github.com/armbian/build/commits/main/patch/kernel/archive/meson-6.1 which means we provide bug fixes even we don't declare hardware as supported.
All fixes that gets to Armbian are integrated at once and update is auto generated within few hours, images once per week.
https://github.com/armbian/community
This is exactly the same support level as other distros, including Dietpi.
There must be some level of confusion because I did submit a fix for the C4/HC4 reboot problems that had been reported for years. I probably should have sent it directly to you.
Many bugs remain unresolved for years and we, by any means, are unable to have complete bug-fix overview in such a complex world.
We can only try to keep some tracking:
https://armbian.atlassian.net/jira/software/c/projects/AR/boards/1/backlog
https://github.com/armbian/build/issues
and resolve when possible.
OK my experimentation has continued and I've discovered an interesting problem. USB doesn't work. I've flashed a vanilla Hardkernel image (ubuntu-20.04-3.10-minimal-odroid-c1-20200519.img.xz) and all is well, ruling out any hardware issue.
lsusb shows the root controller hub on the custom Bookworm armbian build: Armbian-unofficial_25.02.0-trunk_Odroidc1_bookworm_current_6.6.43_minimal.img.
I've plugged in a webcam and a flash drive, non of which appear in lsusb nor generate any stimulus within dmesg.
I've since done git pulls on the repo so I can't tell exactly which git rev this was built on or from; I'd suggest it dates from my last post, Dec 17 2024.
lsusb under the Hardkernel image shows the controller hubs as well as the listing in lsusb, plus dmesg. All seems well.
Any one else experience this?
I don't use USB for my usecase, but I have just plugged in a USB flash drive to test (tested all ports) and can confirm that the hub is detected, but no device plugged into it is detected.
Likely a kernel issue at a guess. I went back to an old build using bookworm but with 5.x and had similar issues although I could boot with USB devices plugged in and then detected, I got many USB bus reset errors and the device was unusable.
Is the correct route here to file a bug?
Hi!
Great to see Odroid C1 is being maintained again!
Since I am using C1 for many years in my homelab I've given it a try.
Unfortunately, after some time under heavier load I start to receive errors, system files becomes unreadable or straight kernel panic:
The SD card is all right, tried different ones, checked cooling, applied fresh paste etc. Nothing.
On the other hand, I've run this board for years with uptimes measured in months with rocksolid 5.11 build by @balbes150 from this thread:
Since download links there are not available anymore, I share mine /boot/ here, maybe it will help somebody:
https://mega.nz/file/nVdjFKSD#zGGyDAJ5YHEY3clyezbHUHMhsItgpzTyvW0Y9uKFVNQ
I've went back to this kernel and it is stable again. Doing well with current stable trixie even. Could you use it to investigate stability issues? Or maybe @balbes150 could share his old patches with current maintainers?
Thanks for your hard work, I appreciate it!
Edited by nef
I wonder if that is related to the issue I've been having. Not long after I posted my last message, I hit an issue where the Odroid would stop allowing me to SSH in (connection refused) but would still respond to pings. I tried with many different SD Cards (and USB Hard disks) and the issue would not go away. Could happen after a few hours or a week or so. In the end I just took the device out of service, as I assumed that it was just dying. My Odroid is headless, so can't connect to console to see any potential error messages. I can't remember how far I dug into logs, but I am sure I must have.
I have now re-imaged it again, with latest Armbian Stable on Trixie, and will monitor it for further issues. I still suspect the device is dying, but your message has given me hope that it is not.
I would be interested to know if anyone else is experiencing similar symptoms.
v25.11 rolling for Odroid C1 running Armbian Linux 6.12.47-current-meson
Packages:     Debian stable (trixie)
Support:      DIY (custom image)
Edited by torz77
@torz77 Without logs and diagnostic information it's hard to tell what is going on because what you're saying is the equivalent of "it doesn't work" :)
Nonetheless I had the same symptoms when my SDcard was dying (bad sectors here and there). The kernel and network layer was loaded in to memory OK, so pings would work, but ssh calls upon extra binaries and files from the SD card and I was getting I/O errors, hence would result in SSH dying which is the connection refused the client sees.
I had to connect mine to a display for the duration of a diagnostic session but thankfully it was easily reproducible so the error glared out. A replacement SD card got me there.
Yeah, I wasn't asking for diagnostics, I realise that this issue could be for a myriad of reasons, just I was sure (before) that it was hardware related, now I'm not so sure. FWIW, it has just happened again less than an hour after boot, so I'm going to pull the card and chroot in to analyse. (I'm a software developer, so am well aware of the 'it don't go, what's wrong?' approach to tech support 😉)
Interestingly, I was still logged in on an ssh shell, and I realised there was an issue when it was telling me that `cat` was an unknown command (clearly not!). I logged out, and now got the dreaded "Connection reset by 192.168.1.44 port 22".
I also ran a full badblocks pass (4 real passes) on the SD card prior to imaging just to 100% make sure the card is fine.
My main concern is that it will not have flushed logs to disk after the issue, so I suspect I will find nothing.
____
Edit:
It looks like Armbian has rsync on a schedule to hold logs in RAM and perhaps periodically copy back to HDD. so unfortunately I have no useful info here. Going to look into the Armbian docs and see if I can get it to log directly to disk whilst I test.
______________
Another edit:
I managed to disable ramlog, but unfortunately nothing of note has been written to the log files. I have tried connecting a monitor via HDMI, but am getting no output. I am sure this is fixable, but not sure how much I'm prepared to fiddle around with a box that just wants to lock up after some undetermined amount of time. I'm going to install the official Ubuntu 18.04 image (urrrgh) and leave it running for a long while. If that displays the same symptoms, then I can safely say this board is e-waste. If it does not, then I will come back to it and try to get myself an output.
Edited by torz77
An update.
I suspect that the issue (or at least 1 issue) is a regression in the handling of MMC (SD card driver in the kernel). I suspect this is a regression as this issue did not hit me on earlier builds.
I set up a netconsole, and received the following stack trace:
[  216.236507] I/O error, dev mmcblk0, sector 849688 op 0x0:(READ) flags 0x84700 phys_seg 1 prio class 2
[  216.524566] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131108 starting block 323201)
[  216.534718] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131109 starting block 323202)
[  216.544920] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131110 starting block 323203)
[  216.560591] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131111 starting block 323204)
[  216.575914] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss!  (inode 131108, error -5)
[  216.587187] Buffer I/O error on device mmcblk0p2, logical block 270977
[  216.601434] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss!  (inode 131109, error -5)
[  216.601564] ------------[ cut here ]------------
[  216.608348] Buffer I/O error on device mmcblk0p2, logical block 270978
[  216.608383] WARNING: CPU: 0 PID: 129 at drivers/mmc/host/meson-mx-sdio.c:446 meson_mx_mmc_irq_thread+0x168/0x174
[  216.608467] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss!  (inode 131110, error -5)
[  216.608485] Buffer I/O error on device mmcblk0p2, logical block 270979
[  216.612894] Modules linked in: rpcsec_gss_krb5
[  216.619667] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss!  (inode 131111, error -5)
[  216.629626]  auth_rpcgss
[  216.629674] Buffer I/O error on device mmcblk0p2, logical block 270980
[  216.629700]  zram
[  216.632164] Aborting journal on device mmcblk0p2-8.
[  216.641941]  zsmalloc
[  216.642033] JBD2: I/O error when updating journal superblock for mmcblk0p2-8.
[  216.648457]  binfmt_misc
[  216.676718] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1639: inode #598: comm dpkg-reconfigur: reading directory lblock 0
[  216.680959]  evdev
[  216.681075] EXT4-fs (mmcblk0p2): I/O error while writing superblock
[  216.683223]  snd_soc_meson_aiu snd_soc_meson_gx_sound_card snd_soc_hdmi_codec snd_soc_meson_card_utils snd_soc_meson_codec_glue snd_soc_core snd_pcm meson_ir snd_timer rc_core
[  216.683268] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[  216.683278]  thermal_generic_adc snd meson_saradc soundcore cfg80211 rfkill efi_pstore pstore netconsole
[  216.744185] CPU: 0 UID: 0 PID: 129 Comm: irq/35-c1108c20 Not tainted 6.12.47-current-meson #3
[  216.744207] Hardware name: Amlogic Meson platform
[  216.744212] Call trace:
[  216.744225]  unwind_backtrace from show_stack+0x10/0x14
[  216.744259]  show_stack from dump_stack_lvl+0x50/0x64
[  216.744275]  dump_stack_lvl from __warn+0x80/0x11c
[  216.744294]  __warn from warn_slowpath_fmt+0x17c/0x188
[  216.744311]  warn_slowpath_fmt from meson_mx_mmc_irq_thread+0x168/0x174
[  216.744337]  meson_mx_mmc_irq_thread from irq_thread_fn+0x1c/0x7c
[  216.744364]  irq_thread_fn from irq_thread+0x134/0x224
[  216.744378]  irq_thread from kthread+0xe0/0xfc
[  216.744396]  kthread from ret_from_fork+0x14/0x28
[  216.744411] Exception stack(0xf1075fb0 to 0xf1075ff8)
[  216.744420] 5fa0:                                     00000000 00000000 00000000 00000000
[  216.744428] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  216.744435] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[  216.744458] ---[ end trace 0000000000000000 ]---
[  217.163204] mmc0: new high speed SDHC card at address 0002
[  217.163907] mmcblk0: mmc0:0002
Which suggests the SD card was connected and disconnected. I have already ruled out faulty SD card (happens on any SD card I use, as well as a thorough stress test on the current card prior to use). Further research tells me "The Amlogic Meson8b (S805) SoC’s MMC controller has known quirks."
I switched to USB rootfs (external HDD), and I still get the same failure, but as it is just the boot partition being unmounted and remounted the system remains up.
Ideally I would propose a patch to fix this, but I am not a kernel developer, and the changes between 3.10 and 6.12 are huge (as to be expected) so identifying what is required and where is non-trivial for me.
For now, I am sticking with rootfs on USB as my interim fix, but I am going to keep netconsole up and monitor over the next couple of weeks to see if we hit another issue (when I tested this in the past, I was also getting failures with rootfs on an external USB stick, so I am not convinced I am completely out of the woods yet).
I wonder if it'd be worth having a look instead at the Odroid stock kernel image and the vanilla kernel of the base same version; see what quirks are needed. I will have a look and see if that diff is less overwhelming than the massive gap you're seeing.
Edited by Tomasz Grzegurzko
Certainly worth a look. It is also probably worth comparing the Armbian commit from when I last had it working until now, but it will need to be when I have a bit more time, and me remembering just when I first started seeing these issues.
I have had a bit of time to do some testing (re: MMC disconnects)
  • This bug does not appear in kernel 6.6
  • A version of this bug appears in 6.10, but without the full trace. Output at the point of disconnect is:
    [ 1082.901830] EXT4-fs error (device mmcblk0p2): __ext4_get_inode_loc_noinmem:4512: inode #25776: block 1769: comm cron: unable to read itable block
    [ 1082.914822] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
    or
    [ 8235.333023] EXT4-fs (mmcblk0p2): shut down requested (2)
    It is worth noting that the device is noticeably more sluggish on this kernel (not measured, and may or may not be related)
  • On kernel 6.12 The bug manifests with a full trace:
    [ 1956.200890] I/O error, dev mmcblk0, sector 9337968 op 0x1:(WRITE) flags 0xc800 phys_seg 1 prio class 2
    [ 1965.163111] rcu: INFO: rcu_sched self-detected stall on CPU [ 1965.165764] rcu: 0-....: (57 ticks this GP) idle=9194/1/0x40000004 softirq=13082/13083 fqs=48
    [ 1965.173801] rcu: (t=2142 jiffies g=20165 q=305 ncpus=4)
    [ 1965.179160] CPU: 0 UID: 0 PID: 78 Comm: kworker/0:3 Not tainted 6.12.49-current-meson #1
    [ 1965.179720] Hardware name: Amlogic Meson platform [ 1965.179991] Workqueue: events dbs_work_handler
    [ 1965.180753] PC is at __netif_receive_skb_core.constprop.0+0x4/0x10a4 [ 1965.181411] LR is at __netif_receive_skb_list_core+0xf0/0x1f4
    [ 1965.181948] pc : [<c10f55bc>] lr : [<c10f674c>] psr: 80030113
    [ 1965.182280] sp : f0801d14 ip : 00000000 fp : c4000000
    [ 1965.182583] r10: c211a108 r9 : 00000000 r8 : c4000000
    [ 1965.182874] r7 : f0801d48 r6 : c400148c r5 : c211a108 r4 : c4e09900
    [ 1965.183225] r3 : c2abbd80 r2 : f0801d44 r1 : 00000000 r0 : f0801d40
    [ 1965.183585] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
    [ 1965.184017] Control: 10c5387d Table: 05ad004a DAC: 00000051
    [ 1965.184260] Call trace:
    [ 1965.184552] __netif_receive_skb_core.constprop.0 from 0xc4003640
    [ 1965.262719] sched: DL replenish lagged too much
    [ 1990.096714] mmc0: card 0002 removed
    [ 1990.100368] Aborting journal on device mmcblk0p2-8.
    [ 1990.100590] JBD2: I/O error when updating journal superblock for mmcblk0p2-8.
    [ 1990.102743] ------------[ cut here ]------------
    [ 1990.111672] WARNING: CPU: 0 PID: 131 at drivers/mmc/host/meson-mx-sdio.c:446 meson_mx_mmc_irq_thread+0x168/0x174
    [ 1990.121734] Modules linked in: zram zsmalloc binfmt_misc snd_soc_meson_gx_sound_card snd_soc_meson_aiu snd_soc_hdmi_codec snd_soc_meson_card_utils snd_soc_meson_codec_glue snd_soc_core evdev snd_pcm snd_timer meson_ir snd rc_core soundcore meson_saradc thermal_generic_adc cfg80211 rfkill efi_pstore pstore
    [ 1990.148744] CPU: 0 UID: 0 PID: 131 Comm: irq/35-c1108c20 Not tainted 6.12.49-current-meson #1
    [ 1990.148779] Hardware name: Amlogic Meson platform
    [ 1990.148791] Call trace:
    [ 1990.148807] unwind_backtrace from show_stack+0x10/0x14
    [ 1990.148865] show_stack from dump_stack_lvl+0x54/0x68
    [ 1990.148921] dump_stack_lvl from __warn+0x80/0x114
    [ 1990.148980] __warn from warn_slowpath_fmt+0x184/0x18c
    [ 1990.149030] warn_slowpath_fmt from meson_mx_mmc_irq_thread+0x168/0x174
    [ 1990.149088] meson_mx_mmc_irq_thread from irq_thread_fn+0x1c/0x7c
    [ 1990.149150] irq_thread_fn from irq_thread+0x138/0x21c
    [ 1990.149207] irq_thread from kthread+0xdc/0xf8
    [ 1990.149270] kthread from ret_from_fork+0x14/0x28
    [ 1990.149314] Exception stack(0xf106dfb0 to 0xf106dff8)
    [ 1990.149339] dfa0: 00000000 00000000 00000000 00000000
    [ 1990.149365] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1990.149388] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1990.149420] ---[ end trace 0000000000000000 ]---
    [ 1990.574529] EXT4-fs (mmcblk0p2): shut down requested (2)
    [ 1991.000606] mmc0: new high speed SDHC card at address 0002
    [ 1991.001627] mmcblk0: mmc0:0002 00000 7.32 GiB
    [ 1991.006695] mmcblk0: p1 p2
    [ 2041.955601] EXT4-fs warning (device mmcblk0p2): dx_probe:823: inode #593: lblock 0: comm bash: error -5 reading directory block
    [ 2041.961894] EXT4-fs warning (device mmcblk0p2): dx_probe:823: inode #593: lblock 0: comm bash: error -5 reading directory block
    [ 2041.974376] EXT4-fs warning (device mmcblk0p2): dx_probe:823: inode #593: lblock 0: comm bash: error -5 reading directory block
If I were to speculate it looks like:
  • initial bug introduced kernel 6.7 to 6.10
  • Bug was identified and the "fix"/"work around" has lead to the more verbose failure somewhere in 6.11 - 6.12
I went for the low hanging fruit first and can confirm the driver meson-mx-sdio.c is unchanged across all versions.
I have also compared the DTBs:
  • 6.6 -> 6.10 Significant changes
  • 6.10 -> 6.12 Identical
The changes looks to be the USB fix. I suspect that the issue is not with the DTB files, as the significant changes will be down to shifting phandle references by +1,
I have now completely ruled out changes to the DTB. I loaded up the 6.12 kernel with the 6.6 DTB and hit the bug fairly quickly (wish I'd done this to start with, to be honest!)
When I next get some time I will start diffing changes to the mmc/core and clk/meson drivers between 6.6 -> 6.10. If anyone else wants to have a crack at this in the meantime, based on the above information, then please, have at it!
Edited by torz77
Updated with latest testing results
At the risk of speaking too soon, I think I have found the issue.
I need to revert some changes, and do some final testing, but hopefully a PR will be inbound to fix this in the next couple of days.
PR Has been merged. I rebuilt on commit 1cf20837d27a3c09d93395f075cc305c81b4663f and things look good.
Build instructions remain the same as my last post on this
   /_\  _ _ _ __ | |__(_)__ _ _ _ ___ _  _ _ _  ___ / _|/ _(_)__(_)__ _| |
  / _ \| '_| '  \| '_ \ / _` | ' \___| || | ' \/ _ \  _|  _| / _| / _` | |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|   \_,_|_||_\___/_| |_| |_\__|_\__,_|_|
 v25.11 rolling for Odroid C1 running Armbian Linux 6.12.49-current-meson
 IPv4:         (LAN) 192.168.1.95, 10.8.0.1, 10.10.0.1 (WAN) ww.xx.yy.zz
 IPv6:         0000:1111:2222:3333:444:555:6666:7777
 Performance:
 Load:         2%                Uptime:       23:36
 Memory usage: 8% of 986M
 CPU temp:     49°C              Usage of /:   15% of 6.9G
Edited by torz77
Add link to build instructions
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
