October 11, 20242 yr Installing: /home/john/Armbian/development_armbian/build/output/debs/extra/jammy-utils/base-files_24.8.0-trunk-12ubuntu4.7-jammy_arm64__1-jammy-1armbian1-Baa17-U12ubuntu4.7-R55fa.deb [ base-files_24.8.0-trunk-12ubuntu4.7-jammy_arm64__1-jammy-1armbian1-Baa17-U12ubuntu4.7-R55fa.deb ] [🔨] '/home/john/Armbian/development_armbian/build/output/debs/extra/jammy-utils/base-files_24.8.0-trunk-12ubuntu4.7-jammy_arm64__1-jammy-1armbian1-Baa17-U12ubuntu4.7-R55fa.deb' -> '/home/john/Armbian/development_armbian/build/.tmp/rootfs-94f20e65-72ab-4c9f-aa58-4f9ea3a1974d/root/base-files_24.8.0-trunk-12ubuntu4.7-jammy_arm64__1-jammy-1armbian1-Baa17-U12ubuntu4.7-R55fa.deb' [🔨] E: Packages were downgraded and -y was used without --allow-downgrades. [💥] Error context msg [ Installation of /root/base-files_24.8.0-trunk-12ubuntu4.7-jammy_arm64__1-jammy-1armbian1-Baa17-U12ubuntu4.7-R55fa.deb failed jammy yes ] armbian ubuntu 22.04 help help.......
October 12, 20242 yr Small hint.. try this: sudo rm -rf build git clone --depth=1 --branch=main https://github.com/armbian/build ..and compile again. In the most cases for me i'ts working again. Markus
October 12, 20242 yr Author Feeling strange ] Installing 76 desktop packages [ jammy gnome ] [🔨] E: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/armbian/pool/jammy-desktop/f/firefox/firefox_131.0.2+build1-0ubuntu0.22.04.1~mt1armbian1_arm64.deb File has unexpected size (66548848 != 66548952). Mirror sync in progress? [IP: 127.0.0.1 7890] [🔨] Hashes of expected file: [🔨] - SHA512:e0fb10ebb4e4c04ce358070f5040242e203f6a2ca8502eb6fbe2eae524cdd94326feb3609d0bd91cfcf9bea471112b10a50afcea7b801e73fcb5aa4af7433f01 [🔨] - SHA256:f32b9e68ce4ecd90e9bd95dc8e2f381d8a9794ececd7e83cdbe28002a84288db [🔨] - SHA1:ed38ecc0a2f30b2c70de29da6b2fb8f219783b94 [weak] [🔨] - MD5Sum:0967d32bcc9990346f253f3c5a51c0db [weak] [🔨] - Filesize:66548952 [weak] [🔨] E: Some files failed to download [🚸] Command failed, retrying in 5s [ chroot_sdcard_apt_get_install_download_only anacron apt-xapian-index at-spi2-core colord cups dbus-x11 dmz-cursor-theme dconf-cli eject foomatic-db-compressed-ppds fonts-noto-cjk fonts-ubuntu fonts-ubuntu-console gdebi gnome-calculator gnome-control-center gnome-disk-utility gnome-desktop3-data gnome-keyring gnome-menus gnome-screenshot gnome-system-monitor gnome-terminal gnome-packagekit gnome-session gnome-shell gnome-shell-extension-appindicator inputattach libasound2 libasound2-plugins libnotify-bin libpulsedsp gdm3 lm-sensors nautilus pavucontrol printer-driver-all profile-sync-daemon pulseaudio pulseaudio-module-bluetooth software-properties-gtk synaptic system-config-printer terminator tracker tracker-extract tracker-miner-fs upower x11-apps x11-session-utils x11-utils x11-xserver-utils xarchiver xdg-user-dirs xdg-user-dirs-gtk xfonts-base xserver-xorg xwayland zenity chromium-browser firefox bleachbit gparted emacs filezilla putty transmission transmission-remote-gtk celluloid eog gimp pithos mpv remmina remmina-plugin-vnc remmina-plugin-rdp ]
October 12, 20242 yr 1 hour ago, lay said: Feeling strange That would be network / mirror sync issue. Try by adding this switch: SKIP_ARMBIAN_REPO=yes
October 13, 20242 yr Author good ! add" SKIP_ARMBIAN_REPO=yes" is natural. and Compile normally. But with its increase, will the things it relies on decrease? What are the consequences of its impact?
