Skip to content
View in the app
Armbian Community Forums
Problems with apt upgrade
Featured Replies
Hello, I have installed NextcloudPi on my Raspberry PI5. Current OS is installed currently:
Now, I would like to make an upgrade and get the following issue.
What can I do?  I am very grateful for any help.
Try an apt full-upgrade. The libraspberrypi packages have been deprecated recently (e.g. June/July) and recent RPI packages shouldn't depend on them, including raspi-firmware.
Edited by mitu
  • Author
Thank you very much for the tip. I have heard that one should avoid updating the firmware if possible. Of course, I don't want my entire system to stop working afterwards. Can that happen? Should I make a complete backup before?
Where did you hear that ? Note that the 'firmware' package is not updating the EEPROM that's present on a Pi4/Pi5 and I had no booting issues updating the raspi-firmware package on RaspiOS.\
Of course you could make a backup if you want to feel safer, but I have no reason to believe there's anything that's going to cause issues if you're going to upgrade the raspi-firmware package.
The following is documented:
Zitat
Troubleshooting
On Debian bookworm variant you might bump into broken packages dependency, conflicts between firmware and bsp package. Here is how you can solve it:
apt update
dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current
apt --fix-broken install
apt install armbian-bsp-cli-rpi4b-current
But nobody seems to read the docs.😪
Raspberry Pi
  • Author
Very good, thank you very much. Stupid question – I have a Raspberry pi5 and the manual mentions rpi4b. Will that work?
  • Author
That sounds good 😃, but is it very risky without a full backup?
Or can I save same special files/directories in case of a system crash? I have waste a lot of time with the raspberry because of many problem. Therefore, I'm a little bit fearful.
Edited by sunshine
  • Author
So, I have now tried to solve the problem using the instructions. But unfortunately, it didn't work and I am getting an error message again. I ask for further assistance.
You seem to have the older obsolete special RPI5 build, that doe not exist anymore, it is just 1 RPI build called 'rpi4b'
So remove armbian-bsp-cli-rpi5b-current as well
apt update dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current armbian-bsp-cli-rpi5b-current
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
