Skip to content
View in the app
Armbian Community Forums
  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Installation of Proxmox VE failed
Featured Replies
I tried to replace PXVirt on my Raspberry Pi 4 (8GB RAM) with a fresh Proxmox installation.
I flashed the Armbian 26.8.1 minimal image and then ran `apt update && apt full-upgrade`.
I started the installation with : armbian-config --cmd PVE001
An error occurred during installation:
An apt update shows
Hit:1 http://deb.debian.org/debian trixie InRelease
Get:2 http://security.debian.org trixie-security InRelease [43.4 kB]
Get:3 http://download.proxmox.com/debian/pve trixie InRelease [4,357 B]
Get:4 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
Hit:5 https://github.armbian.com/configng stable InRelease
Get:7 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB]
Get:8 http://security.debian.org trixie-security/main arm64 Packages [252 kB]
Err:9 https://enterprise.proxmox.com/debian/pve trixie InRelease
401 Unauthorized [IP: 45.144.208.36 443]
Get:10 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index [63.3 kB]
Get:11 http://deb.debian.org/debian trixie-backports/main arm64 Packages T-2026-09-04-2006.30-F-2026-09-04-1415.43.pdiff [1,241 B]
Get:6 http://distrohub.kyiv.ua/armbian trixie InRelease [39.4 kB]
Get:12 http://distrohub.kyiv.ua/armbian trixie/trixie-desktop arm64 Packages [8,515 B]
Error: Failed to fetch https://enterprise.proxmox.com/debian/pve/dists/trixie/InRelease 401 Unauthorized [IP: 45.144.208.36 443]
Error: The repository 'https://enterprise.proxmox.com/debian/pve trixie InRelease' is not signed.
Notice: Updating from such a repository cannot be done securely and is therefore disabled by default.
Notice: See the apt-secure(8) man page for repository creation and user configuration details.
This showed the error.
Any idea what's wrong with the installation?
I would use "pve-no-subscription" and not "enterprise.proxmox".
How to do?
Regards, Markus
Solved by Igor
  • Author
Thanks @SuperKali and  @Igor  ,
The installation starts without errors.
After around 30 minutes i get this screens:
No error messages, but the Proxmox UI doesn't show up on https://192.168.1.30:8006
There is no process i can see on Htop.
Any ideas?
Regard, Markus
vor 1 Stunde schrieb MacBreaker:
Any ideas?
What does your browser show?
Here it is failing dnsmasq.service because port 53 is in use already.
But my installation on vm was with several error messages, but on first try I got access to proxmox, fiddled a little bit, ok, bootet and get the error above.
VM
  • removed Proxmox
  • armbian-upgrade
  • reboot VM
  • installed Proxmox (now without error messages)
Great!!! So nice to get a little test/learning Proxmox instance rapidly, Than You.
  • Author
Hello @Igor,
sorry about the late response.
Everything are working perfect now 😊.
Thanks
Markus
(How can I mark it as solved?)
Edited by MacBreaker
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
