Skip to content
View in the app
Armbian Community Forums
Hope to get rtl8852be wifi driver support for kernel 6.1
Featured Replies
RTL8852BE is the official recommended Wifi module for Orange Pie 5 PLUS, but it is not available in Armbian 24.5.1 Linux Vendor Kernel 6.1 without a driver module. Hope the official driver will be added to the 6.1 kernel. Thanks.
Solved by Gypsophila .
  • Author
Unfortunately, "sudo modprobe rtw89" didn't work.
It returned this with error:
"modprobe: FATAL: Module rtw89 not found in directory /lib/modules/6.1.43-vendor-rk35xx"
I think it may be lost 8852BE kernel module?
In directory /lib/modules/6.1.43-vendor-rk35xx/kernel/drivers/net/wireless/realtek/rtw89, I find "rtw89_8852c.ko", "rtw89_8852ae.ko", "rtw89_8852ce.ko", just without "rtw89_8852be.ko".
  • Author
I have armbian-firmware-full installed. By the way, the config you mentioned in github is linux-rk35xx-legacy(kernel 5.10), not the linux-rk35xx-vendor(kernel 6.1) used in Armbian 24.5.1 Stable.
This topic has also mentioned about the lost rtl8852be driver: No WiFi on latest image - Orange Pi 5 Plus - Armbian Community Forums
Spoiler
Thanks!
Hello everyone!
I have an orange pi 5 plus with the official WiFi module and I have installed thr armbian-firmware-full, but I still can't find the wifi module driver:
user@orangepi5-plus:~$ ls /usr/lib/modules/6.1.43-vendor-rk35xx/kernel/drivers/net/wireless/realtek/rtw89
rtw89_8852ae.ko  rtw89_8852ce.ko  rtw89_core.ko
rtw89_8852a.ko   rtw89_8852c.ko   rtw89_pci.ko
user@orangepi5-plus:~$ ls /usr/lib/firmware/rtw89/
rtw8851b_fw.bin  rtw8852b_fw-1.bin  rtw8852c_fw.bin
rtw8852a_fw.bin  rtw8852b_fw.bin    rtw8922a_fw.bin
I thought it was supposed to be added to the vendor kernel:
https://github.com/armbian/linux-rockchip/pull/192
My kernel version:
user@orangepi5-plus:~$ uname -r
Am I missing something here?
  • Author
  • Solution
Quote
I think It's also wired after that PR the 8852BE driver is still not added into the OS build.
Now I have compile the the DKMS driver by myself, you can simply install it through APT.
Download here
sudo apt install -f ./rtw8852be-dkms_1.0.0_all.deb
Rember to turn off system auto-suspend:
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
 Good luck!
@Gypsophila . I tried with your file, but while the driver is loaded just fine and the WiFi card seems to be running, when scanning for WiFi networks, no networks are found.
I know it should be working as I've tried with the edge kernel and it was working properly.
Any ideas?
Edited by GicaContra
  • Author
@GicaContra I also noticed this problem: first boot can turn on the wifi but can not connect to AP. After install the DKMS driver ,try to reboot twice then it should be worked fine.
Edge kernel is 6.10, the 8852be driver is included in the mainline kernel about 6.2, so it should work, but edge kernel will lost many hardware supports on the board, it's not recommended.
Success!
The repository is at https://github.com/lwfinger/rtw8852be and has detailed instructions to compile and install.
I followed the instructions and have WiFi working again on kernel 6.1.43-vendor-rk35xx
The only difficulty was to find the correct headers package: linux-headers-vendor-rk35xx
My OPi5Plus has the additional WiFi PCIe card, which was visible with the previous vendor kernel version, 5.10.160-legacy-rk35xx or package linux-headers-legacy-rk35xx.
Though managing both cards used to be buggy, I only see one card now. Not perfect but enough for my current needs.
Edited by bolet75
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
